PaulB1803
Member Since 10 Sep 2011
Offline Last Active Today, 09:48 AM
#173051 Illuminated Ignition Ring.
Posted by PaulB1803 on 17 March 2012 - 05:03 PM
That'll be the same guy Lenny linked too. I also got several items from him too, he's top class. :)
#170327 Illuminated Ignition Ring.
Posted by PaulB1803 on 03 March 2012 - 06:17 PM
Received mine last week but it was faulty. :( replacement arrived today, fitted and working brilliantly. Should make getting the key in the ignition a sight easier in the dark, and also looks very nice.
#158425 Guide To Fitting Mist Type Jets On Your Ford
Posted by PaulB1803 on 28 December 2011 - 07:58 PM
Cheers Lenny, fitted these today following your guide. Made it very easy indeed.
#158214 Retro-Fitting Bluetooth To A 58Plate Titanium
Posted by PaulB1803 on 27 December 2011 - 06:14 PM
I have the cruise control....its weird, do you have the microphone place in your light fitting also?
No idea tbh, but i will have a look tomorrow.
#154149 Ford Focus Rear Badge Brake Light
Posted by PaulB1803 on 26 November 2011 - 10:58 PM
Cheers Lenny, thats brutal!!! Will be worth it when its done. :)
#154119 Ford Focus Rear Badge Brake Light
Posted by PaulB1803 on 26 November 2011 - 09:33 PM
Come on then, share..... ;)
#154110 Ford Focus Rear Badge Brake Light
Posted by PaulB1803 on 26 November 2011 - 09:14 PM
Paul they don't remove easily , double sided taped , thats ford try to make sure won't come apart lol.
but if you insist. Lenny go to Paul's house and remove that badge B)
Plus mine seems to have been glued too. Ill just put up with it. Note to self, never give Lenny my address. ;)
#153463 Guide To Fitting Door Handle Smd Led's Mk2.5
Posted by PaulB1803 on 21 November 2011 - 11:36 PM
hmmm, might be one step far those lol
#153462 Bulb Light Changing
Posted by PaulB1803 on 21 November 2011 - 11:35 PM
Absolute doddle to change them. Remove headlight with 1 screw and all bulbs are easily accessible. It's all in the manual too. :)
#153398 Bulb Light Changing
Posted by PaulB1803 on 21 November 2011 - 04:05 PM
Yes, osrams for full beam. The Bluefield ultras come with 2 sidelight bulbs in the pack. The less are brighter than standard and look brill. Will find a link, but they were £3.79 off Ebay. The leds get nowhere near as hot as halogens.
#153375 Bulb Light Changing
Posted by PaulB1803 on 21 November 2011 - 10:34 AM
I put Philips Bluevision as dipped, osram nightbreaker plus for Mains. also leds for sidelights. Big improvement over the existing bulbs in both looks and performance.
#153279 Guide To Fitting Door Handle Smd Led's Mk2.5
Posted by PaulB1803 on 20 November 2011 - 11:39 AM
Got mine fitted yesterday morning. Encountered a few problems along the way though.
Broke a clip on the rear driver side door card putting it back on :( decided to fit the rest without removing the door cards. It was a bit more fiddly but I managed ok. Scotchlock connectors refused to make a proper connection so I ended up stripping a small part of the cable and then using the scotchlock. Even though mine is also a titanium, the wires were different colours to preees. Not having a multimeter I judt poked the led cables in the ends of the comnector to see which worked.
All in all, I'm really happy with the result, and even the missus said they looked better than she expected!
Thanks again preee. :)
#153136 Paid Members Privalages
Posted by PaulB1803 on 18 November 2011 - 09:54 PM
:lol: I purposly spent hours counting the little black dots on the window both sides of the car to ensure they were perfect lol how sad is that :lol:
Lol, and i thought it was only me that did that type of thing!
#150741 Guide To Fitting Door Handle Smd Led's Mk2.5
Posted by PaulB1803 on 31 October 2011 - 10:33 PM
Thanks Preee. :)
