Member Since 15 Nov 2008
Offline Last Active Apr 09 2009 07:44 PM
central locking problem
15 November 2008 - 05:55 PM
The central locking on my wifes Focus 1.8 Ghia 02 plate has a fault.
When I try to use the fob it locks then immediately unlocks, the only way the lock the car is to go round to the passenger side and lock it by putting the key in then turn, then you can press the the fob and double lock the car. You cannot do this from the drivers side for some reason.
Any help would be greatly appreciated.
Many thanks, :P
sticking throttle
15 November 2008 - 05:48 PM
I have just joined and have a question I hope someone can help me with.
My fiesta 1.8td flight 51 plate has a problem with the throttle, it starts normally then aftera few minutes normal driving the revs get higher and stay there until I reset the ignition by quickly flicking the key off and on without turning the engine off.
After the few minutes I have to repeat this procedure.
Thanks :P
