if the clutch was going wouldn't it be in all gear's and more the lower gear's..
this sounds more like a gear selector issue and maybe something as simple as the gearstick not moving far back enough it select sixth....
- → Viewing Profile: Posts: andthen
Support the club!
- Group Members
- Active Posts 20
- Profile Views 650
- Member Title Member
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Male
Ford Model
mk4 mondeo zetec with sports pack
Ford Year
2009
UK/Ireland Location
Lincolnshire
Annual Mileage
10,001 to 15,000
Contact Information
- First Name mike
1
Neutral
User Tools
Friends
andthen hasn't added any friends yet.
In Topic: 2003 Tdci 6 Speed Wont Go Into Gear
25 June 2012 - 07:31 PM
In Topic: Help Accessing Usb Port In S-Max
25 June 2012 - 07:13 PM
hi there ... if your car has the sony dab , it will play mp3 files and the connector itself is only a few quid..
there will be a blanked plug on the left side of the glove box when you remove it . two main bolts on the roof of the box and several screws scattered around the front....
instead of going though all that you can play music thou your bluetooth from most new phones;-))
In Topic: Tyre Pressor Sensor/valve
07 May 2012 - 05:23 PM
hi there ,
I have just removed the last of four from my 2009 car with less than 40k on her..
There is a serious desgin fault with them , why replace if they will fail in the next year od so.
Up until the fourth sensor my dashboard display gave me a tyre pressure sensor warning , but now all four are removed the system has switched it's self off....
Think i can live without it.....;-)
In Topic: Help!! Mondeo Rear Window Has Shattered For No Reason
18 February 2012 - 09:33 PM
my brother had a rear window go like this in a sierra years ago , it was in the winter and there was a sudden thaw once night
....his car was snowed/iced over when we letf it but when we returned the following morning the sudden thaw had caused his rear window to completely shatter........
In Topic: Adding an ipod adaptor - Can it be done ?
30 January 2012 - 08:37 PM
Hi there .
I may have some info which might be of use.
If you go to the mondeo page and i have a topic titled "is there a hidden usb port in a mk4 mondeo???"..
Now it turns out if you remove the glove box there is a blanked out plug on the left side , now one man on there assures me that if you buy a usb plug from Ford and he quotes £2.70 , he now has full i control on his steering wheel ..
i'm have the blanked out plug in my 59 reg mondeo and will be searching from the plug this week .
i let you know what happens ;-)
I wouldn't put i pass Ford to charge £50 for a three quid bit!!
- Privacy Policy
Find content
