Druberry
Member Since 02 Oct 2011
Offline Last Active May 12 2013 09:13 PM
In Topic: Mk2.5 Focus 2010 leaking
24 May 2012 - 11:23 PM
Yes Mick it was when I parked uphill that I noticed the leak. when ford check it out for leaks they use a dye. good luck.
22 May 2012 - 09:20 PM
The same problem has just started on my 2009 Focus, front and rear foot-wells on the drivers side are both very wet, I phoned the local ford dealership who told me water ingress is only covered in the 1st year of warranty. They said they would take a look and do an initial water test for around £50 then if they found anything they would try to get Ford to cover the cost., but I'm extremely dubious this would happen, I'm very disappointed with the situation it could end up costing me a fortune.Could anyone tell me how the water gets from the front to the back foot-well, (my car is always parked facing uphill on a steep drive)
Sorry to here your having the same problem as I had mick, Mine still stayed dry since the repair I might add. mine was leaking between the dash bulkhead and the side bulkhead, the garage did say after they found the leak realised it could have been repaired from the wheel arch, the plastic wheel arch has to be removed, then the leak was because of the missing sealant near the top of the seam,as my dash was removed they were able to repair both sides. After I got the car back I put my arm right up to the top right hand side of drivers footwell behind the dash and I was able to feel the new sticky sealant that the garage repair my car with. I really hope this helps as I was so frustated when mine leaked however I do check from time to time just in case. also I parked facing up hill to. goodluck Andy
28 November 2011 - 08:12 PM
Leak Update.
Today I picked the car up after dropping it off at the garage no the 21st. Since then the front doors and dash were completely removed (they showed me photos as I asked) and they said they were able to immediately see where the water was coming in, as Chris said in earlier post. There were quite a few places where the sealer was missing or cracked so they repaired them all to be on the safe side. Its now just a matter of time and constant checking before I can be sure it is water tight, but I am pleased with progress so far.
Thanks again Chris for your valuable info.
Andy
17 November 2011 - 06:59 PM
Chris
Garage phoned me to say they had the car for 10days took carpet out put 1 seat back in drove it around in rain but could not find any source of leak, so got it back Tuesday, next day heavy rain, a very small wet patch next to inner sill so I put some tissue paper there, but no rain since and it is now dry again. Its a real mystery, I did ring the garage and told them of the leak, they booked it in for next week, but now there is no evidence. I told the garage of your plight, but they did not respond. Was your leaking all the time or just when you parked it a certain position, (uphill, etc). I can see why others have simply moved the car on as it gives you no confidence what so ever.
Regards Andy
In Topic: Water Has Leaked Into The Boot Plz Help
13 November 2011 - 12:10 AM
Hi Jamie
I hope this is the end of your problems but my focus is a 60 plate as welland reading about leaks ford are just not getting their act together, its an old model now so you expect these problems sorted. As you can see from my post, we should not be having these issues.At least you never had to pay for it. All the best Andy.
