B.J
Member Since 04 Oct 2011
Offline Last Active May 02 2012 06:44 PM
In Topic: Sreetka Hazard Lights Wont Turn Off
20 April 2012 - 03:06 PM
HI THERE I HAVE THE SAME PROBLEM WHEN LOCKING THE CAR WITH THE KEY FOB THE HAZZARD LIGHTS START FLASHING AND WONT STOP UNTIL YOU UNLOCK THE CAR SOME PEOPLE ON THIS WEB FORUM SAID IT MIGHT BE SOME OF THE MICRO SWITCHES LOCATED IN VARIOUS PLACES ON THE VEHICLE I TRIED THIS TO NO AVAIL STILL SAME PROBLEM DONT KNOW WHAT TO DO, SO THE ONLY WAY I HAVE FOUND IS TO LOCK THE VEHICLE WITH THE KEY ITSELF PROBLEM SOLVED FOR ME ANYWAY. IF YOU DO FIND AN ANSWER LET ME KNOW.
AS TO YOUR REAR BOOT IF ITS THE SOFT TOP VERSION OF THE KA LIKE MINE I HAD THIS PROBLEM AND AGAIN THIS WEB FORUM IS A GREAT SOURCE OF INFORMATION, I WAS TOLD THAT WHEN YOU PUT THE HOOD BACK UP AND CLOSE THE STEEL COVER WHERE YOU SOFT ROOF GOES IN IF BOTH SIDE OF IT DONT LOCK DOWN PROPERLY YOU CANNOT OPEN THE BOOT SO HAVE ALOOK AND MAKE SURE IT LOCKS DOWN BOTH SIDES THEN YOU SHOULD BE ABLE TO OPEN THE BOOT WITH YOUR REMOTE.
HOPE THATS AS CLEAR AS MUD LOL...........
In Topic: Constant Hot Air
16 October 2011 - 09:23 PM
OK THE STORY SO FAR HAVE CHANGED THE HCV VALVE AND HEY PRESTO WE HAVE HEAT CONTROL FANTASTIC NO LONGER ROASTING MYSELF TO NEAR DEATH, GOT A NICE BRAND NEW ONE OFF EBAY 14.99 FREE P+P. TESTED BEFORE FITTING IT TO SEE IF IT OPENED AND CLOSED JUST TO MAKE SURE ALL IS OK.
THE RADIO WAS JUST THE AERIEL LEAD NOT CONNECTED SIMPLE FIX.............
THE PROBLEM WITH THE ALARM STILL ELUDES ME HAVE TRIED BOOT MICRO SWITCH SEEMS OK HAVE ALSO TRIED SOFT TOP MICRO SWITCH THIS ALSO SEEMS TO WORK JUST GOTTA TRY THE BONNET SWITCH WILL CLEAN IT UP AS SUGGESTED.
WILL ALSO ATTEMPT TO CHECK FOR ANY AIR LOCKS AS SUGGESTED.
APPART FROM THAT ALL SEEMS GOOD.
MANY THANX TO BTMALDON FOR ALL YOUR HELP AND SUGGESTIONS CHEERS MATE..................... ;)
15 October 2011 - 08:52 PM
Ok thanks for your reply got my hcv through the post so am gonna fit this tomorrow and see what happens, as for the switch underneath the bonnet I have found this it does move up and down as you say can it be taken apart to clean it will the rubber boot come off havn't tried yet as I dont want to tear it, and if I did have an air lock in the system how do I remove it???
thanx John............
13 October 2011 - 06:43 PM
THANX FOR YOUR RESPONSE WILL LOOK INTO ALL THE ISSUES CAN YOU PLEASE TELL ME WHERE THE SWITCH FOR THE ALARM IS UNDERNEATH THE BONNET, ALSO ON THE ISSUE OF THE ENGINE SEEMS TO RUN HOT BUT WITH NO PROBLEMS AT MOMENT DO THESE KA'S TYPICALLY RUN HOT???
DOES THE HEATER CONTROL VALVE HAVE WATER INSIDE?
THANX JOHN.........
