On my 52 plate Ka when the headlights are on they start at normal brightness and go brighter then go to normal brightness,I have placed a multimeter on the battery with the engine off,it reads 12volts so battery ok,if I start the engine with multimeter still connected to the battery I get a fluctuating reading between 13.4volts and 15.4volts,I do not get a constant voltage,it seems to me the voltage regulator on the alternator seems to be not working.
My Query is can the regulator be renewed on a modern alternator,in my younger days i renewed a regulator in a Lucas alternator on a Mk2 Escort.
Also how do you identify which model of alternator is fitted without removing it,if I have to replace the alternator.
- → Viewing Profile: Topics: Budgie650
Support the club!
- Group Members
- Active Posts 11
- Profile Views 1,723
- Member Title Member
- Age 49 years old
- Birthday June 14, 1963
Gender*
Male
Ford Model
Ka
0
Neutral
User Tools
Friends
Budgie650 hasn't added any friends yet.
Latest Visitors
Alternator Problem
24 January 2010 - 08:39 PM
Engine Misfire
14 December 2009 - 11:17 PM
After servicing my 52 plate Ka,changed plugs,oil change,air filter change,the engine now misfires when putting your foot down,could it be a dud spark plug,or the HT leads.
Blistering Paint around filler cap
19 September 2009 - 07:58 PM
The paint work around the filler cap is blistering on my 2003 Ka is this a common problem and is it repairable.
Headlight Condensation
19 September 2009 - 07:54 PM
On my 2003 Ka i am getting condensation in the drivers side headlamp is there a cure or is it a new headlamp unit.
- Privacy Policy
Find content
