adder360
Member Since 07 Oct 2011
Offline Last Active Nov 10 2013 03:23 AM
In Topic: Guide Fitting Cruise Control Focus Mk2 & Mk2.5 And Ford C-Max
24 October 2013 - 10:12 PM
just got my cruise control activated after over 6 months of trying with elm config.
Attached File  pcm 2.JPG   84.57KB   8 downloads
were it says pcm type I selected the 1.6 tdci option from the list, hadn't done this before and it gave me an error did it not and it read no problem.
finally got it sorted after wasting 40 quid at a ford dealer for them to plug it in buying 2 elm readers both modded and working at 500,000 if any one would be looking to buy one send me a message.
23 October 2013 - 12:05 AM
I am getting the same issues as carl0s. also getting this Attached File  elm.PNG   27.25KB   35 downloads when trying to read on the pcm page 2.
im using a wired elm connector I've got 2 and tried both and get the error message both. on the speed test they both show are able to connect at 500000. is any one able to shed any light on this. mine is a 1.6 tdci I read on other pages that this was not supported in previous version of elmconfig.
thanks
In Topic: Guide To Replacing Reverse Light Switch
04 July 2013 - 02:25 PM
It is located as the normal air filter is I just took the picture of it before I put the top of the air box back on
In Topic: Guide To Installing A Reverse Parking Camera
17 May 2013 - 02:25 PM
my reverse camera and sensor screen
In Topic: Guide: Fitting Egr Blanking Plate 1.6Tdci Engine
05 May 2013 - 03:39 PM
hello, i followed youre guide the other day and fitted one. well i say followed youre guide i tried to do it with out taking all the wipers off at first but i had to in the end because you just cant see.
much more even pull dont feel a masive dead spot at the lower revs well worth the low price.
good guide :)
