adder360
Member Since 07 Oct 2011
Offline Last Active Nov 10 2013 03:23 AM
Guide To Replacing Reverse Light Switch
04 July 2013 - 03:38 AM
I had some problems with the activating of my reverse lights and
then my reverse parking sensors and camera. I did some fault finding
and found out it was the switch so I bought a new one decided to
write it up as I couldn’t find much helpful on the topic.
I did this on an 09 plate 1.6 TDCI so might be different for outer
types
I used the following tools:
22mm double depth socket (and ratchet)
7mm socket + ratchet +extension
8mm rat ring (could use a small 8mm socket and ratchet)
first I used the 7mm to remove the cover of the air box (4 bolts)
Attached File  20130703_161125.jpg   99.05KB   111 downloads
then I removed the air filter and prepared to remove the air box
Attached File  20130703_161306.jpg   115.54KB   143 downloads
I then removed where the air box is connected to the engine by
removing what im guessing is the air flow meter 8mm 2 bolts
Attached File  20130703_161324.jpg   159.13KB   149 downloads
now the elastic holding the air box down at the front needs to be removed
Attached File  20130703_161354.jpg   242.51KB   166 downloads
now this is detached the box will just pull out from the 2 rubber mounts and from the pipe at the front, it takes some wiggling, now you can see the switch
Attached File  20130703_161801.jpg   168.54KB   190 downloads
using a piece of wire you can confirm the switch is faulty and the rest of the circuit is ok.
Attached File  20130703_162015.jpg   168.1KB   187 downloads
as you can see you need a double depth to fit over the plug part
Attached File  20130703_162219.jpg   181.31KB   167 downloads
the 22mm socket just fits over the switch and I attached the ratchet and removed it, it becomes lose after just un nipping it
Attached File  20130703_162243.jpg   112.85KB   142 downloads
I could put my hand to the left of the battery so I was able to see what I was doing when putting the new switch in
Attached File  20130703_162737.jpg   256.06KB   125 downloads
now was just a case of testing and putting the air box back, whilst I had the air filter out I thought I might as well put a green cotton one on :)
Attached File  20130703_163809.jpg   133.76KB   97 downloads
I hope this is helpful
