ajt
Member Since 09 Oct 2011
Offline Last Active May 24 2013 07:41 PM
Help Please, Dash Pod Gauge
17 April 2013 - 08:28 PM
Im hoping someone can help me out.
I recently acquired a dash pod gauge, and following Lennys guide, want to fit it to my TDCi. I want to keep the original gauges and drive them of the canbus. My problem is that there are alot more pins than I expected. I think I have worked out that all the pins I want are on the same row, and I think the order is as follows
1. Can H (?)
2. Can L (?)
3. Think Power + (maybe dial illumination)
4. GND
5. Power + (IGN)
6. Power + (Perm)
On the other row appear to be at least two pairs of DATA lines and another GND.
I have applied power to 4 and 6, then jumped 6 and 5. This cause the gauge to zero, pulling about 90ma dropping to about 35ma a few seconds later.
I know the middle boost gauge only reads to 1.2 bar, and on a diesel you will need 2 bar for full boost, but the gauge actual has a sweep of about 345 deg (almost one complete cirlce. So if I just offset the needle to be horizontal pointing to the right, then two bar would be approximately horizontal to the left. Anyhow, getting into irrelevant detail until I can work out for definate which pins to use. So on with my plea for help:
Can any body offer a wiring diagram, take a picture of the actual plug (fitted in RS and ST I believe), or attempt to decode the colours and location of the attached picture (You wouldn't believe how long it took me to find this!)
Attached File  dashpodback.jpg   18.32K   29 downloads
Retro Fit Washer Level Sensor
03 April 2013 - 07:43 PM
When I first tried the ELMconfig utility, see guides, I turned on the low washer level warning, which I then quickly turned off as it always chimed I had low level. Oviously sensopr was not fitted.
The main reason I want this facility is because it is most annoying when you get a dribble and it only smears and makes the windscreen even more opaque. The fact that it is illegal to drive with an empty washer bottle, well there's another good reason.
As we all know the level of the bottle cannot be seen without removing offside wheel and wheel arch liner. Now I don't mind doing this once a week....oh no wait, I mean how stupid that the level cannot be determined without stripping the car.
So I thought it cant be that difficult to retro fit so off to ebay I went.
I purchased an secondhand vauxhall omega level sensor, main reason being that it came with the rubber grommet attached. Less than a fiver delivered. It was waiting for me when I came home for lunch, so I stuck my multimeter on it and found it had a resistance of approximately 200ohms when closed and infinite when open, so seemed ok to me (though I must admit I assumed it woould read closer to 0Ohms when closed).
I miced the grommet at its thinest poit and found it to have a diameter of 19.86 mm. So i took an old mop bucket (flat sides) and drilled an 18mm hole. I pushed the grommet in and then the sensor into the grommet. Perfect fit. Went back to work.
Left work just after 4 and stripped out the water bottle. I was slightly disappointed to find no plug for a sensor, but did note that the connector feeding the washer pump had an additional 4 wires in it, and noted two of these to be both Orange/black, which to me implies they should be connected by perhaps the level sensor! So off i went.
1. The inside arch of the washer bottle had a nice flat, with a circle marked on it. I used this as my template to drill and proceeded to make an 18mm hole (with a step drill).
2. The rubber grommet has a flat on it, which lined up exaclty with the flat on the washer bottle.
3. I then extended the wires from the sensor, and cut the orange black wires going to the socket and joined the two pairs together with bullet connectors.
4. Used ELMConfig and turned the warning back on, but could not get it to trip the warning with a completely empty or full bottle. So put it all back together and shall have a play at the weekend.
Update (couple of hours later):
It is now working, with no other changes see post 5 and 6
Tdci 1.6 Mk2 Injector Sealing Washer Size
16 March 2013 - 10:41 AM
Can anybody tell me the size of the sealing washer for the diesel injector on a MK2 1.6 TDCI ,07 plate.
Diameter and thickness.
I went to MVC and was told they couldn't get one as they have to be order through Ford only!
Went to indy motor factor, and he said "what size do you want?" and then pulled out a box with lots of bags in!
How easy is it to change the washer?
Whoosh, Pop Then Loss Of Power
15 March 2013 - 06:58 PM
Driving back to work today after liunch, put foot down a bit in second (to get through traffic light, which was still on green but about to change), I felt the car start to pull, heard a whoosh sound followed by a muffled pop and then loss of power.
I limped back into work, getting a whining noise on acceleration and acceleration was very poor, struggling to get to 20 up a hill.
I then limped home about 5.30 and took the engine cover off expecting to see the intercooler pipe blown off, but it wasn't. I looked around the pipes I could get to, but could not see any splits or displaced pipes.
I also removed the inlet to the turbo and could spin the turbo. The spindle has no in/out movement, but does have slight up/down wobble.
I should also like to point out that over the last couple of month I have noticed a tghe car doesn't pull as good as it has in the past. (just put it down to cold weather) and fuel consumption has gone up to (again put it down to cold weather).
Last oild change was 5 months ago and the intercooler pipe was also replaced about same time, due to split in elbow.
Anybody have any thoughts as to what to check in the morning when the sun rises?
(TDCi 1.6 2007)
