sparkymark75
Member Since 10 Oct 2011
Offline Last Active Yesterday, 09:11 PM
Favour If You Have A Mk4 Mondeo
30 April 2015 - 08:05 PM
If you have a post 2008 Mondeo with the factory fitted sat nav and voice control, would you be able to message me your registration number?
I retrofitted the NX unit and my factory fitted voice control no longer works. I tried fitting a new jumper cable which I thought would fix it, sadly it didn't. So to figure out what microphone jumper cable I need, I need to lookup a car in Ford eCat which already has it all fitted as standard to find out which part is fitted.
Fitting Ford Nx Sat Nav
04 March 2015 - 01:04 PM
I have a 2009 Titanium X Sport which came factory fitted with the Sony 6CD DAB head unit. It also had fitted the Bluetooth+Voice Control module (8M5T-19G488-AL).
Last weekend I swapped out the Bluetooth module and replaced it with a 8M5T-19C112-AT part and connected the associated cable to get USB connectivity which worked straight away with no extra configuration.
I plan to fit the Ford NX Sat Nav unit (Part No: 7S7T-18K931-BL).
The part I'm stuck at is I've seen people referring to a jumper cable they had to fit so that voice functioned correctly as the NX has it's own microphone. I'm not exactly sure what this cable is and it's part number. I'm thinking it's a 22 pin plug and the part number may be 1592581 however I'm not 100% sure.
Does anyone have any idea what this part is?
Thanks.
Dealer Service - Software Updates
01 March 2015 - 04:49 PM
If you get your car serviced at a Ford dealer, do they usually check for software updates as part of the service or is it something you have to ask for and pay extra for?
Favour To Ask Someone With Factory Fitted Sat Nav
23 February 2015 - 11:44 PM
I'm trying to get a price for the fascia that surrounds the Sat Nav unit. As I have a Mk 4 Titanium X Sport, I have the Piano Black fascia's with my current Sony head unit. The problem is FordPartsUK can give me a price but the part info they have doesn't give the colour info.
They have said that if I can give them the reg plate of a car that has it, they can figure out which part it is.
So if you have the NX Sat Nav unit with the Piano Black surround in a Mk 4, would you mind PM'ing me your reg number?
Facelift Headunit Into Non-Facelift Car
22 February 2015 - 12:35 PM
I have a 2009 Mondeo with the Sony 6 CD DAB unit. I may be able to buy the factory fitted sat nav head unit from a 2010 Mondeo. My question is, will it fit?
