Mitsimatt
Member Since 18 Oct 2011
Offline Last Active Jul 01 2012 12:56 PM
I'm Gonna Blow My Car Up!!!!!
26 November 2011 - 10:08 AM
I have a focus tdci had problems with a injector spent 144 for a recon one fitted it and still running rough takes about 5 mins to start and it smokes so much I have replaced most of the sensors cleaned the egr valve new fuel filter and bg244 and still the same it does have power when it's warm it flys then when slow down again then try too floor it no power goes slow and judders had it on a snap on diagnostic and it keeps saying maf sensor it can't be its new end of my tether what do I do?
Where Is Everyone From?
12 November 2011 - 01:10 PM
Hi just wanted to know where everyones from I'm from Aylesbury near Milton Keynes.
Turbo Problems
11 November 2011 - 09:32 PM
I think I have a problem with my egr and turbo switch things lol I floor it turbo kicks in for a second or two then no power I have taken out the vac pipe on the box on the right side it's like a vac reserve it's tdci 1.8 when I do that there is power all the way to 5k it pulls hard then I put it back in it only revs to 4k and no real power Im using bg244 done 60 miles so far and cleaned it egr valve and changed most of the vac pipe with new and checked for any air leaks any ideas guys
Turbo Issues
11 November 2011 - 09:31 PM
Starting To Hate My Focus
03 November 2011 - 06:14 PM
Right I have replaced map,maf and crankshaft sensor and still having problems in the morning I start it loads of mixed smoke black,blue sounds like it ls misfiring have to rev it hard to stop it running like !Removed! the smoke clears driving it around feels like hesitating juddering it dosent do it all the time and feels like the turbo is holding back not giving me all the power as I say it does it most of the time then it runs fine sometime and when it does it goes like !Removed! of the shovel I have no warning lights and when in neutral I rev it and it hits the limiter then do it again it hits the limiter but lower revs about 3,000 rpm it doing my head in only had it for a few weeks and spend a small fortune on it just want it to run normal of once please help thanks
