Member Since 19 Oct 2011
Offline Last Active Dec 26 2014 08:12 PM
#423560 Bluetooth
Posted by sambooka on 28 October 2014 - 06:35 PM
reset the Bluetooth module Nathan did a video on how to do it think its in the guides section
#317727 New Fiesta 1.6 Tdci Owner
Posted by sambooka on 04 January 2014 - 01:46 AM
As above as long as you give it a good run sort of 20 mins half hour at motorway speeds is more than enough for the car to do a regen cycle on the dpf. I also have a 1.6 tdci the turbo lag is just something you put up with in the beginning until you adapt to it or floor it so it's always on boost like me :). The ecu could be anything mine was recalibrated just for 17" rims. So could be anything
#301242 Replacement Alloy Wheel?
Posted by sambooka on 31 October 2013 - 04:55 PM
Well I went for 17" fox racing fx004s I wanted a sort of rs style
#287549 Ford Fiesta Mk 7 Alloy Size
Posted by sambooka on 04 September 2013 - 06:26 AM
I believe so yes my aftermarket alloys are 42 and I've never had any problems and ford never said anything when it's been in for services
#287386 Ignition Live Help
Posted by sambooka on 03 September 2013 - 05:15 PM
Why not test the port for f25(drl) to see if its live and just use that it should be ignition live either that or use the 60a one you found and fit an inline fuse
#286575 Interior Plastic Removal Help ?
Posted by sambooka on 01 September 2013 - 03:29 PM
I can't tell if that link has worked because I'm on my phone it just shows a blank post but if you search nathDOTso on YouTube there's a video called interior plastics removal all you need to know I'd on that
#286574 Interior Plastic Removal Help ?
Posted by sambooka on 01 September 2013 - 03:18 PM
Nath to the rescue again
#281885 Z-S Spoiler On A Zetec?
Posted by sambooka on 12 August 2013 - 06:32 PM
Yes you might need to extend the wiring for the bake light and the windscreen spray though
#280210 Puddle Lights And Spacers
Posted by sambooka on 05 August 2013 - 08:49 PM
If you want to buy uk to support the economy buy silver ones from a uk sell then support your local paint shop aswell. You will be able to get black ones but they will take a bit of finding
#276161 Alloys Or Steel
Posted by sambooka on 19 July 2013 - 08:01 PM
Definitely alloys aftermarket though as fords were a bit soft
#272279 Horn Only Partially Working
Posted by sambooka on 02 July 2013 - 07:11 PM
Either bad earth or not enough voltage getting to it. Make sure it's earthed to a clean piece of metal ie no rust
#233764 Diesel Fuel In Engine Oil
Posted by sambooka on 06 February 2013 - 10:02 PM
This may explain why I've never had to top my oil up and is this normal as mine did this once before about a week after the service light came on and now its done the same again
#233550 Diesel Fuel In Engine Oil
Posted by sambooka on 06 February 2013 - 08:06 AM
Mine has also recently come up with this symbol but mine is due a service as I've done nearly 12000 since the last one never knew it meant fuel in oil though I have the same engine as you 95bhp tdci
