Member Since 23 Nov 2008
Offline Last Active Nov 23 2008 01:08 PM
In Topic: ford fiesta heaters
23 November 2008 - 12:54 PM
You could try taking the dash off an seeing if the cable/control behind the heating dial on the dash has broken or become disconnected? If all else (head gasket, heater itself) is ok might be something as simple as a snapped cable to the heater control.
In Topic: fusion performance parts
23 November 2008 - 12:47 PM
Realise this isn't a busy thread, but figured I'd ask - is it worth chipping the 1.4 diesel and does it make much difference to its sluggish performance?
I've had my leon (tdi 150) chipped since 2k miles and its hard to drive the car without it - feels like a snail unchipped - so figured it'd be worth doing the same to the wifes car to make it a bit less 'challenging' at junctions and when the road opens up a bit. Might be better on fuel too hopefully with not having to thrash it so hard. The Leon does about 4-500 on a tank depending on driving but chipped tends to do a few more mpg thanks to more torque less hard work, hopefully the little ford might do the same.
