Member Since 24 Nov 2008
Offline Last Active Nov 24 2008 05:40 PM
In Topic: Ford fiesta flame 4500 series (3 "section") stereo head unit
24 November 2008 - 04:40 PM
normally that means theres an internal problem with the cd player... ford can send it back to get it fixed n itll cost ya.. so will buyin a new ford cd player... best off buyin a new head unit u like itll cost alot less
In Topic: Warning Light
24 November 2008 - 04:37 PM
if its flashin its normally flashing a code 3blinks in 3 seconds means summat n 4 means summat else.. the dealer will be able to put it on the ids and tell u exactly wot is at fault
In Topic: broken seat release - advise please
24 November 2008 - 04:35 PM
there talkin a pile of !Removed!... its a common problem with them fiestas im a fully qualifyed ford mechanic its covered upder warrenty use to replace 4 a day... the cabel snaps on them or the release handle bracket to where the cable is inserted breaks and they ALWAYS replace both.. go in an tell them its covered under warrenty u rang ford direct and they advised you to take it to your local dealer an make them aware u know that its covered under warrenty m8
