Member Since 29 Oct 2011
Offline Last Active Sep 25 2015 12:51 PM
#526344 Guide Fitting Cruise Control Focus Mk2 & Mk2.5 And Ford C-Max
Posted by simonaldridge82 on 25 September 2015 - 12:51 PM
hi do not panic you can remove the air bag charge from your steering wheel and fit into the air bag unit on the st wheel. I have done this and got some photos somewhere. you will also need to change the resistor values in the cc switches I found the wiring diagram and the values of resistors near the beginning of one of these posts. just let me know if you want to do this will not take long.
#266906 Towbar Wiring
Posted by simonaldridge82 on 10 June 2013 - 09:03 PM
if you pull off the lower door trims you can push the wire all the way without taking your car to bits. in the boot lower trim remove 4 black plugs first then they all the panels pull off. 2 torx screws hold the sides . remove the screws and you will then gain enough access without taking them off just pull them out a bit. make a hole in the grommet in the floor you will see it push your wire through cable tie it out of the way of your exhaust pipe .
