pragmatix
Member Since 16 Nov 2011
Offline Last Active Nov 14 2012 12:35 PM
In Topic: One Way To Get Your Car Ad Noticed !
15 July 2012 - 07:26 PM
That sort of thing was rife on ebay a few years ago, allsorts of stuff that had reflection in them kettles, pans, mirrors, and cars
In Topic: Can You Recemend A Good Glass Cleaner
10 July 2012 - 12:46 PM
Vinegar and water, then polish of with paper towel
In Topic: Cant Add/change My Profile Photo.
23 June 2012 - 06:32 PM
Same  prob here cant change pic, no error messages the pic changes on the profile page but then reverts to the original pic IYSWIM
In Topic: Sounds Like My Exhausts Blowing Under Load But Its Not
21 June 2012 - 09:20 PM
hi Alex and welcome
Did you change the clutch/flywheel yourself?
not sure what your exhaust problem could be though if its leak free? perhaps one of your silencers is nackered
Or it drumming on the chassis, also check the turbo pipe front right as you are looking at the car this can hit the chassis leg and sound like blowing
In Topic: Apparent Uneven Engine With Loss Of Power At Medium Revs
19 June 2012 - 07:32 AM
also try checking the turbo boost pipe which runs up the front of the engine on the left as you look at it. these can also split giving the hic up as the turbo spools up.
Not that on mine been through most things all seems well only happens at 1500rpm on a light to trailing throttle
