Member Since 26 Nov 2011
Offline Last Active Feb 02 2014 09:43 AM
#158933 Ford Fiesta Mk6 Water Pump Question
Posted by ging on 01 January 2012 - 06:07 PM
his is true the kits are not expensive and they go into the back of the cams and fits flush to the top of the head so you will also need to remove the rocker cover i would also fit a neww rocker gasket at the same time some people reuse them but i prefur to replace than reuse its not hard to do if you have the correct equiptment
#158899 Mondao Probs
Posted by ging on 01 January 2012 - 02:39 PM
if the fuse is ok then use a power probe or multimeter to check the lights are getting some power to them and go from there the revs going up and down sounds like you may have a dogey idel controlo valve i would give it a clean then refit it if this dont work i would replace it they are not expensive ging hope this helps
