For the price of a haynes manual it's not worth the hassle trying to find a pdf online, brand new they don't cost much and there's always ebay
I got one for my escort tddi off ebay for just over a fiver ... get your wallets out cheapskates!
- → Viewing Profile: Posts: Ecky
Support the club!
- Group Members
- Active Posts 17
- Profile Views 378
- Member Title Member
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Male
Ford Model
Turbo Diesel Escort Estate
Ford Year
2000
UK/Ireland Location
Bridgend
Annual Mileage
10,001 to 15,000
Interests
Classic Cars
General Automotive
Motorsport & Racing
Car Restoration
Car Modification
Computers & Electronics
General Automotive
Contact Information
- First Name Alun
In Topic: ford escort mk6/7 manual pdf??
28 January 2013 - 11:09 AM
In Topic: What Is The Standard Boost Pressure For The 1.8 Turbo
08 May 2012 - 11:21 PM
Ah, on the tddi like I have the intercooler's mounted above the exhaust manifold ... I've heard them described as an 'interwarmer' lol
I don't realy know anything specific about the tdci (22psi at stock tho seems quite a lot to me), just know a little bit from reseaching stuff about the tddi because I have one, boost dropping off though is I believe caused by insufficient fuelling needed to maintain max boost
The tddi has a mechanical fuel pump so you can adjust fuelling by turning screws, but I don't think the tdci is mechanical in which case if you want gains a remap might be worth considering, do more for your car than just a boost controller, especially if the max boost drops off because the remap (should) aim to give best possible 'balance' between boost and fuel/air flow
Incidentally, other than accelerating up to speed, in fifth with the throttle opened up enough to be boosting away at 15-20 on a motorway mine would be doing well in excess of 120kmh (that's 75mph right?), once up to that speed if I back off the throttle to maintain 120kmh steady it's barely boosting at 10psi
Which makes me wonder if someone might have increased the boost on yours but neglected to do anything about fuelling, just seems to me if it's at stock to be producing that much boost you just gotta be putting your foot down pretty hard and only doing 75mph?
Good page on manual boost controllers: http://www.boostcont...y_page.php?i=19
In Topic: Ford Escort 1.6 16V Ghia From 1999 Temperature Problems
08 May 2012 - 09:43 PM
Another issue known to cause erratic behaviour of the temp gauge is a bad earth to the gauge/clock
Worth checking
Worth checking
In Topic: Escort Mk6 Cheap Brake Upgrade?
05 May 2012 - 12:18 PM
Cheers for that vinny
I have the standard 15 inch wheels on both cars though, the diesel has a set of wolfrace which I got cheap and spent much time and not an insignficant amount of money on paint etc to refurb, the gti wheels I I stripped the paint off and polished them to a mirror finish then lacquered, again, hours and hours of work!
So I think for now a brake upgrade will have to wait, at least until I make the effort to find some bigger wheels and spend the time effort'n money refurbing those
Anyone wanna buy a nice newly & professionally painted set of 15 inch wolfrace?
05 May 2012 - 12:09 PM
He did ask what the STANDARD boost is
I have a 1.8 turbo diesel endura-de with a boost controller and I've also tuned the diesel pump a bit
When I first fitted the boost controller, before tuning the pump and with the controller turned right the way down it was getting around 12psi but when you fit an mbc (manual boost controller) the boost will increase slightly even before you turn it up so newbie wouldn't be far off when he said the standard boost was 10
You can't really use the figures for a tdci like lenny's as a guide for the tddi engine which the OP has, different fuel pump and ecu I believe
My tddi escort currently runs at about 17-18psi though I have ran it at 20, even 22 for a test, but you shouldn't run it at more than 20 really without a front-mounted intercooler and usually when you do a front mount intercooler conversion you're also fitting new and maybe stronger pipework. Running it over 20 with the stock top-mounted intercooler you run he risk of turbo pipes blowing off and/or splitting, damage to the turbo itself not to mention the chance of blowing your head gasket
One thing to understand tho, increasing turbo pressure without also increasing fuelling to match it does nothing for the performance of your car, this is where tuning your diesel pump comes in
You probably have a lucas diesel pump and there's loads of articles about tuning these on the web but there's more than one way to do it, the most comprehensive (possibly the best) guide I found is on the turbo diesel owners club uk website
- Privacy Policy
Find content
Latest Comments
More
