salsheikh
Member Since 07 Dec 2011
Offline Last Active Today, 12:36 PM
#489722 Ideas For The Front Of A Mk 2
Posted by salsheikh on 26 May 2015 - 07:06 PM
a facelift bumper would be too much work but a pre facelift ST bumper would be a straight fit.
this guide will be of use to you:
http://www.jamessimp...-st-lookalike/
#488443 Focus Mk2.5 St2 Mot Failure - Headlamp
Posted by salsheikh on 22 May 2015 - 08:51 AM
Does that include me then?
your the worst of the lot  :P
#488168 Quick Question!!
Posted by salsheikh on 21 May 2015 - 12:41 PM
i'd stick to what you have personally. there is nothing wrong with it and it will do the job perfectly fine. like the rest of us you have seen a better product and felt the urge to improve what you have!
#487530 Not Sealed Item/used.
Posted by salsheikh on 19 May 2015 - 12:54 PM
if it was listed as new then i would fully expect a seal on it. take a pic and query it with amazon
#486406 Focus Crash Simulator Educates Young Drivers
Posted by salsheikh on 15 May 2015 - 11:47 AM
i saw this and immediately thought thats a Focus RS :D but then realised its an ST  :o
#486015 Focus Mk2 Custom Sub Enclosure
Posted by salsheikh on 14 May 2015 - 10:15 AM
i have a similar set up to Hassen - i used a 10" amplified kit and mounted the amp inside the box
my sub sticks out a bit as its deep and i used mdf rings (ebay) to overcome this issue.
#482770 Split Pipes
Posted by salsheikh on 05 May 2015 - 01:27 PM
washing up liquid on any rubber pipes and then get a mate to rev the car - look out for any bubbles that appear an this will tell you where the leak is.
also check all jubilee clips to ensure they are nice and tight, if you see any oilish residues then change the clips for newer and better ones.
#482767 Mk2.5 Focus 1.8Tdci Exhaust
Posted by salsheikh on 05 May 2015 - 01:23 PM
3" will be too much (i think subaru's have that size), stick to 2.5"
straight through pipe will do the job but you may have an issue come MOT time if there is no 'visible' cat!
oh and enjoy the whistling sound it will create - i hope you have deleted the EGR too.
#482756 Are 30 Mm Lowering Springs Even Noticeable
Posted by salsheikh on 05 May 2015 - 12:48 PM
you'll be surprised at the difference 30mm of lowering can do to a car!
#481281 Lift And Tilt
Posted by salsheikh on 30 April 2015 - 01:40 PM
thats exactly what i have!
#480426 Mft Screen Wallpapers
Posted by salsheikh on 28 April 2015 - 08:18 AM
i have one but its NSFW!
#476697 Help 1.8Tdci Egr Valve
Posted by salsheikh on 15 April 2015 - 08:01 PM
this is what you need:
http://www.ebay.co.u...=item20eccbd0c6
to paste links on here, click the toggle switch in l/h corner in the above taskbar and then paste the link in the reply box and voila it works!
I thought it was a Microsoft issue until I discovered this!
#474709 My St / Rs Mk2 Build Up. Project Phenomenal!
Posted by salsheikh on 09 April 2015 - 02:20 PM
this link will give you an idea of where the clips are:
http://www.ebay.co.uk/itm/GENUINE-FORD-FOCUS-ST225-BOOST-GAUGE-6M5T10B944AD/161642156878?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D30111%26meid%3Dbebe2822a7204f6b96fdd76450b7ef89%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D321718420769&rt=nc
#474685 My St / Rs Mk2 Build Up. Project Phenomenal!
Posted by salsheikh on 09 April 2015 - 12:52 PM
Nah i am ok doing it myself.....i just cant find an access point to pop off the pod that holds the guages....thought there might be a knack to getting it off.........methinks taking out the radio etc and unclipping from underneath might be a bit of a job?
Im in Newcastle btw. : )
it is easier to remove with the radio out the way. the pod is held in by tabs that you need to unclip - i used a flat screwdriver from the top in one edge and prised it out slowly but safest way is by removing the radio.
#472406 A Flat Battery Can Strand You..... What Would You Do ?
Posted by salsheikh on 02 April 2015 - 02:55 PM
get into the boot by dropping the back seats? lower the drivers/passenger seat low enough to get into the back or squeeze through if you aint a big fella.
get your battery checked out just in case it is faulty.
come to think of it, last time i looked i couldnt access the earth cable due to how the battery is situated so jump starting could have been a big no no. looks like keeping a spare battery is the only way to go!
