anton b
Member Since 17 Dec 2011
Offline Last Active Apr 28 2012 11:04 PM
In Topic: Interior Light
09 January 2012 - 09:03 PM
Although I really like the sunglasses holder I'm not brave enough to start cutting into the roof lining. Also don't want to replace the fitting and lose the ambient lighting. Just good to know which fitting has the same W5W socket I can use to replace the lost one.
Thanks again
09 January 2012 - 08:19 PM
Hi mate,
this unit will fit as an upgrade if you like Click Here i saw other MK7 owners fitting the sunglasses holder,
and the light unit will fit your existing slot but you wont have use for the ultra-sonic alarm beams that are fitted on either end of the light unit, but your existing light unit will fit the same sized slot if you take the bulb socket from the light and fit it to your existing one it will be a direct replacment B)
Brilliant, thanks very much. :)
09 January 2012 - 07:54 PM
Hi Mate,
the units on the focus and mondeo are all the same part so yes if you buy one on ebay the fitment is identical to your existing one ;)
Thanks for the quick reply, would it matter which mondeo it was? as there seem to be more mk3 interior lights available than any other model.
09 January 2012 - 07:40 PM
Went to local dealer today and was told I could only order a whole new fitting for £40 not just the small bulb holder to fit into existing fitting.
Does anyone know if I was to buy a different ford courtesy light fitting on ebay (not necessarily fiesta) do they all take w5w and would it have the part I require?
03 January 2012 - 06:54 PM
Thanks for that, unfortunately I got that far myself and managed to slightly damage the fitting in the process so the fitting moves slightly upwards now as you press the left reading light. The holder actually ended up between the metal of the roof lining out of reach with every attempt to retrieve it pushing it further away. I last heard it slide across as I went round a roundabout and have not heard it since. I will contact my local dealer to see if I can sort out a replacement.
