STEADS
Member Since 02 Jan 2012
Offline Last Active Today, 11:05 AM
#474374 Alloy Wheel Refurb
Posted by STEADS on 08 April 2015 - 04:46 PM
Ditto with mark wheel specialist proper job has them do my Range Rover wheels about four years ago still look like new today
#469688 Focus Zetec S Grille Badge....found !!!!!!
Posted by STEADS on 25 March 2015 - 07:41 PM
That great be havin myself one of those and I bet it gets delivered quicker than Royal Mail
#469400 Problem With Car/mechanic
Posted by STEADS on 25 March 2015 - 05:13 AM
Have you got the old water pump if so can you post a pic on here you will be able to tell if the damage to it is recent or old by looking at it old will be where the veins have come off wil be totally discoloured new will be all clean looking my suspicions are they have just got hold of an old water pump snapped the veins off and said there you go .
And think bout it what's in there apart from from water to snap all the veins off never come across one yet that has had one vein snapped never mind the lot .
#467698 Focus Mk2 Leaking Coolant - Possibly Found Solution
Posted by STEADS on 20 March 2015 - 12:15 PM
You don't say what focus you have mk1 /2 /2.5 will help people give advice by looking at the photo I think it might be the reverse light connection check with it off then attached usual suspects for coolant leak are water pump and thermstat housing what side of the engine is the leak from cambelt end pos water pump gearbox end pos thermostat housing front of engine on a 1.8 TDCI thermstat housing .
#467132 Quad Exhaust Unusuall Problem
Posted by STEADS on 18 March 2015 - 10:58 PM
The one on mine is a powerflow cost 250 from deeside powerflow extra 50 quid for the other pipe which I havnt had put on yet
#451139 Any Help Be Great
Posted by STEADS on 03 February 2015 - 11:20 AM
Yer sender would still work and I have heard of it being done the way you suggest but I would certainly get your friend to scan it first as I might be wrong but my mate had the same prob and symptoms on his 16 replaced the pump and everything back to normal
#450751 Any Help Be Great
Posted by STEADS on 02 February 2015 - 05:44 AM
I'm sure these have a common problem with the pump going altogether only cure is a replacement for which you have to drop the tank
#444405 Air Blowing / Whistling Noise
Posted by STEADS on 13 January 2015 - 03:29 PM
More surprised at 20 quid to do two jubilee clips up
#443816 Antifreeze Reservoir Issue
Posted by STEADS on 11 January 2015 - 03:51 PM
Yep it's broke should be one piece
#443451 Zetec S Rear Bumper Lookalike
Posted by STEADS on 10 January 2015 - 12:08 PM
New shape can't help you on bumper as not sure on that one on the mk2.5 you could just by the extension piece sure someone will let you know soon enough .
#443447 Zetec S Rear Bumper Lookalike
Posted by STEADS on 10 January 2015 - 11:52 AM
Is yours the new shape focus or a late plate mk2.5
#442881 2.0L Turbo Diesal Struggles When Raining/surface Water
Posted by STEADS on 08 January 2015 - 12:53 PM
Check your air filter reason I say this had a 2.0 a while back bought it with a problem the air filter looked as if it had been wet/damp at some point and if so would stop air flow so it is a possible cause worth a look .
#432719 Manufacturers Service Or...?
Posted by STEADS on 29 November 2014 - 02:13 PM
I'd say find your self a reccomended Indy that's outragous for a service and they charge them prices cos people tend to be naive I wouldn't dream of paying any where near that when I worked for an Indy years back the only difference between what they called a full service and engine service was that we used to check the brakes over .
#432714 Timing Belt And Water Pump Change..
Posted by STEADS on 29 November 2014 - 02:05 PM
I believe it's around 110,000 might be advisable to do both in one hit save money if the pump goes at a later date .
#430593 Front Bumper Hanging Off
Posted by STEADS on 22 November 2014 - 06:36 PM
You should be able to redo that by just removing the wheel arch liner get a tap hammer a tap down where it has pulled the plastic screw fixing throug the hole either that or just a good a fix tie wrap it bumper to wing done that before looks just as good
