Hi folks
im intrested in buying another mondeo its got 97,000 on the clock 18" alloys, with 4 good tires on got all the extras just had a full MOT put on it
the bloke whos selling it want £2000 what do you think got a few pics of it.
regards john
- → Viewing Profile: Topics: 1djspikey
Support the club!
- Group Members
- Active Posts 60
- Profile Views 491
- Member Title Settling In Well
- Age 33 years old
- Birthday November 16, 1979
Gender*
Male
Ford Model
ford mondeo estate ghia 2.0 tdci
Ford Year
2002
UK/Ireland Location
Derbyshire
Annual Mileage
0 to 5000
Interests
General Automotive
Car Modification
Computers & Electronics
General Automotive
Previous Fields
Location
ripley in derbyshire
4
Neutral
User Tools
Latest Visitors
Ford 2002 Mondeo 2.0Tdci Zetec Leather St Look
09 February 2012 - 12:36 PM
2.0 Zetec Or Duratech Tdci Engine
08 February 2012 - 07:52 PM
Good evening folks
Just out curiosity which engine do you prefer in your motors 2.0 zetec or duratech ??
be nice here your thoughts and opinions
regards john
regards john
One Injector Got A Leak !!!
01 February 2012 - 09:08 PM
Good evening all
i have a 2.0L TDCI engine euro 3 type and after having 2 or 3 codes read outs and clearing the code faults by ford to find out why my car goes into limp mode with the glowplug light flashing and no engine managenent light on ford told me it was the fuel pump solenoid so i bought a new one from a auto parts for £69 + vat
the problem still is on going i have notice that the 1st injector on from the lefthand side as got a slight wet ring of diesel around it i got the engine warm took the car for a run and tryed to boot it before going in to limp mode went back home and lift the bonet and the injector was slightly more diesel around it but after a few hours it as dissappeared would this be the cause of my problem i was wondering if when getting engine boost off the turbo it might be drawing air in causing it to go in limp mode am i right or wrong can some one point me the right way thats had this problem i have also notice the electric plug is soaked in side but i havent unpluged it in case it made things wores with the ECU.
regards john
regards john
Is It A Common Fault On Mondeos ?
24 January 2012 - 10:36 AM
mornning folks
after having a Diagnostic and getting a read out with the codes
U1900 CAN Communication Bus Fault
P0100 Mass or Volume Air Flow Circuit Malfunction
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P1665 Injection pump control module communications
P1664 pump control module malfunction
P1211 Injector Control Pressure Sensor Above / Below Desired engine running
P0251 Injection Pump Fuel Metering Control A Malfunction
ive taken the car to another garage showed the man the codes a couple of phone calls later he came up with it must be a dry wire or loose wire.
cause the car is running fine and not showing the signs of anything mechanical plus its a common fault on these cars to cause a electrical damage faults is this true as he wants to get a auto electrics man on the job to sort the wiring out as anyone had this problem before ?
spike
spike
Been For A Diagnostics Test Today
20 January 2012 - 08:57 PM
Hi all
been for a Diagnostics test on my 2002 mondeo estate ghia 2.0 tdci euro 3 that goes into limp mode and glow plug flashing heres the codes ive been given
i also had a vacuume pressure test on the EGR and was working well plus i did clean it all out a few weeks back so this problem was wiped off the list
the turbo is vacuume actuator as been tested and is running fine and turbo is not that old by the looks of it pretty clean
as anyone got any ideas and thoughts ??
regards spike
regards spike
- Privacy Policy
Find content
