Support the club!
Air Hostess
Member Since 06 Dec 2008
Offline Last Active Aug 07 2012 08:55 AM
In Topic: Help Required
10 October 2010 - 01:43 PM
ALP1101 thanks,
I did try all the menu's before I contacted the dealer and there were none that would do it
Unlock the car. Press and hold both the lock and unlock buttons for about 7 seconds. The indicators will flash 3 times.
This works on my three door so should work on your 5 door
Fordpartsman,and Mark T,
thanks for that,and yes it did work,should have thought of that one as thats what i had to do on my Mondeo,I did try that on the 6.5 Fiesta and it didnt work,had to use the menu's..........so I thought i would have to use the menu's on the MK7..........wrong........... so thanks guys, I think Ford Technical Dept need to get its act to-gether as I will be contacting the dealer to-morrow to tell them "how to do it",which will be interesting especially from a female......lol
Best wishes
Kristal
In Topic: Trip Computer
14 July 2010 - 04:05 PM
hey guys
bit of simple/silly question do all mk6 1.4 zetecs have trip comps with what mpg your doing how many miles you have in your tank etc??
cheers
SL
  Not sure about the early ones,but my 2008 mk6 facelift does,average MPG,average speed, range at full tank, miles till empty,and trip meter,plus loads of other things that are accessable through the computor, hope that helps
Kristal.
In Topic: Clutch Pedal Problem
26 June 2010 - 01:39 AM
The clutch is operated by hydraulics, and the fluid is shared with the brake system. It may just be needing a change of fluid, as it pulls moisture out of the atmosphere, and has a change-interval of 2-3 years. Otherwise, there is an old problem with the short rod linking the pedal to the clutch master cylinder;-- many people have needed new clips to secure the rod in place. P.S., the clutch slave cylinder is down in the bowels of the clutch bell-housing, and can leak, but will top itself up from the reservoir at the main hydraulics reservoir. Check the level. A leak at the slave cylinder is ominous and can knacker the grip of the clutch. That would need a new clutch assy. with slave cylinder and fluid and bleeding.
I have almost the same problem,when changing gear the pedal sometimes sticks on the return and suddenly pops up as your driving.its going in for a new master cylinder on the 3rd July (as per senior tech at lookers ford) so will let you know if it cures the problem...glad it under warranty.........
Kristal
In Topic: Km To Miles
19 March 2010 - 02:16 PM
Hi need help
just got my 58 reg focus. The milage is showing 'miles' and my tripmeter is showing 'km'
is there axway to change both to 'miles'
cheers
should be able to reset it with the onboard computor toggle switches .see owners manual .......(i think)
In Topic: Mk7 Fiesta Titanium 1 : Mk2 Focus Rs -500
19 March 2010 - 02:11 PM
Perhaps, or the "here you go spoilt child, you're now insured on my fast new car"
for some of the longer serving members on here ..does that remind  you of someone that used to post on here.post after post after post...............nuf said
