aliislekzade
Member Since 12 Jan 2012
Offline Last Active Apr 12 2013 04:52 PM
In Topic: Ford Focus 1.6 Petrol Ti-Vct P0016 Fault Code
11 March 2013 - 09:00 PM
lights gone off by itself , we didnt clear it, i drive approximately 15km and light gone off while driving car.
and engine noise gone off after changing timebelt , its running like new car, no noise at engine.
they just change engine oil and timingbelt.
11 March 2013 - 07:05 PM
i solve it. it is from timing belt :) i change it , my car is ok now , and engine is perfect :)
timingbelt was orginal ford factory made time belt , from 2006 ;
first my car give P0420 Error Code: Catalyst System Efficiency Below Threshold
then it gave P0016 - Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
after 3 monts its gave  P0341 camshaft position sensor A/ Bank 1 CKT(circuit?) range performance fault and not starting,
thats all abaut old timingbelt , i changed it and its fixed, engine is perfect now.
thank u :)
23 January 2013 - 11:06 PM
thanks for your helps... i will go ford garage next week
23 January 2013 - 10:21 PM
thank you very much..
i will go to ford next week , and i will tell them fault code , and i will see whats the problems amount :(
i will write it here.
i hear that there is some engine cleaner , thats you put it in engine oil ,and run engine , and then change all oil from engine , its clean the engine they said,
is it usefull for me ? in these condition
23 January 2013 - 09:36 PM
because 1 part in ebay is £15 , but same part in my country £100 :(
