brian1106
Member Since 15 Jan 2012
Offline Last Active Mar 06 2013 09:57 PM
In Topic: 2012 Focus Titanium Chrome Dis Colored
17 September 2012 - 08:23 PM
ye
i believe the strip has a fault in it. the service guy at the dealer suggested that it was sun cream mistakenly applied by kids, i did not quite laugh at him but replied that the kids must have been real good as that strip has the same apperance at its full lengnth only on the front passenger section of the strip and the same kids would have to applied the sun cream under the mirror not leave any finger marks on it or anywhere else on the car ...... where do they find these people
In Topic: Startup Trouble For 2005 Mk2 1.6 Ti-Vct
17 September 2012 - 07:09 PM
if you are saying that the engine turns over excessively before it fires up,then you may have trouble with the cam shaft or crank shaft position sensors. simply put older engines were all mechanically linked injection pump is timed and driven by the engine. newer engines are electronic and need to know where in the 4 stroke cycle it is. it uses sensors to check this position and if one sensor is giving trouble the engine needs to turn over more to find where in the cycle it is before it can start. if you have a problem with the sensors it should record and error code.
17 September 2012 - 06:23 PM
Attached File  17-09-2012 focus chrome on the rear passenger door.jpg   71.44KB   58 downloads
here is how it should be see the reflection in the chromeAttached File  17-09-2012 focus chrome on the rear passenger door.jpg   71.44KB   58 downloads
17 September 2012 - 06:19 PM
pictures
17 September 2012 - 06:18 PM
Attached File  17-09-2012 focus chrome on front passengers door poor finish 002.jpg   52.74KB   63 downloadsAttached File  17-09-2012 focus chrome on front passengers door poor finish 002.jpg   52.74KB   63 downloadsAttached File  17-09-2012 focus chrome on front passengers door poor finish 001.jpg   83.38KB   40 downloads
