MisterC
Member Since 24 Jan 2012
Offline Last Active Mar 16 2012 06:30 PM
In Topic: Ford Fiesta Annual Maintenance Service
25 January 2012 - 03:09 PM
It looks like the OP is not from the UK so I'm not sure what the servicing schedule is like in their country,
I am in Luxembourg and the servicing schedule is the same with UK (1 year or 20,000 kms [12,500 miles]).
25 January 2012 - 03:06 PM
The first service has an oil change, so no problem with that. The second service is identical to the first, so you have not been chaarged extra. Total cost of service about £150.
Sorry, I meant "break fluid change" instead of "oil change" which is normally done on the second year. Based on the checklist from Ford Etis, the battery check should also be done on the second year. These two costs €48 (€35+€13) which I should have only paid on my next service.
25 January 2012 - 02:33 PM
depends when the noise is, if its on start up then its perfectly normal as far as i am aware... and as for the service, i had my oil topped up on my first one as it was border-line low, not quite an oil change but they said it was needed... so best bet is just continue asking
Sometimes the noise is there and sometimes it is not. Sometimes it's on start up and stays until I park at the office (5km drive). I'll check it thoroughly during the weekend.
Sorry for the typo in my original post. I meant "break fluid change" instead of "oil change". I believe the break fluid should be changed on the 2nd year at the earliest.
