PantherPL
Member Since 26 Jan 2012
Offline Last Active Apr 24 2013 06:22 AM
#254161 Help Please, Dash Pod Gauge
Posted by PantherPL on 21 April 2013 - 08:25 PM
Hi ! I'm from Poland :)
I tried install gauges from ST to TDCI. Unfortunately, gauges doesn't work. Works only oil pressure.
Turbo and oil temperature doesn't work :( Mayby TDCI doesn't have map sensor and oil pressure sensor.
Here you have a connection :
1,2 - battery 12V
3 - ground
4 - ignition 12V
5 - can -   ( pin 17 in main gauges / cable color : blue/red )
6 - can +  ( pin 18 in main gauges / cable color : gray/red )
7 - ilumination - battery 12V
Sorry for my english.
#221830 Guide Fitting St Gauge Pod To Focus Tdci Dash
Posted by PantherPL on 18 December 2012 - 11:45 AM
Hey,
my name is Arthur. I'm from Poland.
I found your description of the installation of dashpod of the Focus ST. I wanted to ask you - is it possible to install the original ST dashpod to Focus 1.8 TDCI with original electrical harness? I found the wiring diagrams in which it is written that the oil temp, turbo work by installing the HS-CAN.
Sorry for my English.
Greetings from Poland
