Member Since 29 Jan 2012
Offline Last Active Dec 16 2014 07:35 PM
In Topic: Ford Focus 1.6Tdci 57 110 Acting Strange
12 February 2014 - 09:52 PM
I hope it works for you mate as it hasn't for me, after a day or so I was getting errors again so I've plugged it back in,  where did you get it remapped?
In Topic: P2584 Eml
23 January 2014 - 08:38 PM
The noise when the warning light comes on, the bleeping, why wouldn't the dashboard trick work though? That's what's concerning me as well
In Topic: P2584 Eml
23 January 2014 - 07:58 PM
Yeh it's running great apart from the !Removed! warning light and noise!! It's a bit strange though that the dashboard trick don't work though don't you think?
In Topic: P2584 Eml
23 January 2014 - 06:50 PM
Well, I've been back and had another map put on the car by the same guy. Surprise surprise same problems yet again. I really don't know what to do with this now, really f@@ked off!! Incidentialy I thought I'd do the dashboard trick and see what errors that flagged up! I can't get it to work at all tried everything, could this be related?
In Topic: P2584 Eml
04 January 2014 - 09:55 PM
Just checked and yes, this connecter has been disconnected on mine - I assume this was done as partof the dpf removal.
The light you are showing (looks a bit like an engine block to me, not sure if its meant to) is a general engine malfunction warning according to the handbook, "go immediately to a ford dealer and get ripped off big bucks to have it reset".  It doesn't sound like its specific for dpf, although mine was one before getting tyhe pdf taken out and most of the error codes were dpf related.
Thank you for checking, i really appreciate it!! Unfortunately the place where i got it done is closed until the 7th so ill have to see what happens then.
