Member Since 18 Feb 2012
Offline Last Active Apr 17 2012 11:57 AM
Ford Freaks Blue Oval Night - Thursday 26Th April, Car Meet At 8 Ball Diner
16 April 2012 - 08:48 AM
Time for all local Ford Freaks to head to the 8 Ball. The best Diner in Essex – the home of UK Fords
26/04/2012 7:00 pm
26/04/2012 11:00 pm
Address: The 8 Ball Diner – London Road – A12 Northbound – Witham – Essex – CM8 3HB. Telephone: 01376 573403
United Kingdom
Help With Location Off Gem And Kvm
09 April 2012 - 09:13 PM
Need any help finding the Generic Electronic module and the keyless vehicle module any ideas were they can be I've checked above the fuse box and behind the left side boot panel cannot see no modules ?
Engine Fault Light
08 April 2012 - 09:01 PM
Ok wile on a mission to try and fix my central locking I was checking all the plugs and fuses I started with a big brown plug that sits unders the interia fuse box pulled that out all looked well poped it back in wrong and started getting all sorts of problems limited acceleration limited epb ESP all sorts so when back to the fuse box saw I put that big brown block in wrong put it back in correctly bit now I'm getting engine fault up with the red light any suggestions
Driver Door Will Not Unlock With Key And Sometimes Will Lock
02 April 2012 - 01:36 AM
Can someone help as this is buggin me, My Driver door won't unlock with key sometimes will lock with key if I get it to double lock using the key then I'm able to use remote fob to unlock my car, but if I do lock it with the key and it only locks once then fails to lock I'm left having to open the boot using key climbing all over my seat wile the alarm going off to unlock my car from inside very annoying lol when the drivers door fails to lock I find pulling on the inside door release leaver then I'm able to lock it sometimes, so frustrating also the fob doesn't lock it either just unlocks aslong as the car is doubled locked, not sure if its all connected to the same fault causing these problems, I've tried wd40 and had no luck I've took my door panel off but had to stop as there a plate of metal witch I think hold the window up so will have to wait till got time too get behind it if I need too, some advise would be very much appreciated, also it's a 2004 focus cmax
Airbag Light On Constant But No Always On? Cmax 2004
13 March 2012 - 03:53 PM
Hi any ideas my air bag light is on constant, don't get any flashing I start the car and about 7 seconds after started the airbag light comes on, was off for few days then wile driving today it came back on, I read someone saying bout dodgie wires but I'm not sure what wires to be checking, any help would be appreciated
