Member Since 21 Feb 2012
Offline Last Active Apr 26 2014 05:23 PM
#356023 Mk7 Fiesta On Focus Rs Wheels
Posted by Wilko-S1600 on 22 April 2014 - 09:43 PM
They suit the car very well.  Looks brilliant :)
You going to have them black?
Thanks. I think I'll get them done either in the same colour or an anthracite.
Man they look sick!! But look seriously low to me? How much you dropped it by? Do the fronts rub on the arches? Must be close aint it? But love them do you have more pics?
It's lowered 55mm but this pic was with 40 profile tyres and it rubbed really badly. I've got some 35 profiles now and it's a lot better, still pretty close to the arch... no more pics at the moment but I'll get some soon
Sent from my GT-N7100 using Ford OC mobile app
#355993 Mk7 Fiesta On Focus Rs Wheels
Posted by Wilko-S1600 on 22 April 2014 - 08:40 PM
Hi guys,
Not been on here in a while so thought I would share how my car is currently looking. Bought a set of MK1 Focus RS wheels for the S1600 which I think look really nice!
Going to be getting them refurbished soon so they should look even better!
#185372 Fiesta Mk7 Drl Fitting Guide!
Posted by Wilko-S1600 on 03 June 2012 - 11:26 AM
Another Pic of them fitted:
#183072 Fiesta Mk7 Drl Fitting Guide!
Posted by Wilko-S1600 on 17 May 2012 - 05:36 PM
Fitted some DRLs to my MK7 today so thought I would do a quick guide on how to install them.
First up you need to buy a set of DRLs. There are loads of options for this and it is down to personal preference which ones you want. I bought some flexible LED strips. http://www.ebay.co.u...984.m1497.l2649
Next up you need to get a relay. This is needed so that the DRLs turn off when your headlights turn on. Here is the one I bought:
**********EDIT 11/11/2012*************
Right so I decided that these LEDs looked naff when they wernt turned on so I wanted to do something about it. Here is what I did:
I bought some 70mm CCFL Halo rings. These DO NOT work with a DRL inverter as they have their own power ballasts.
Unfortunately i dont have a link to the rings I bought.
I then took the actual CCFL ring out from the halo's plastic case, leaving me with the plastic shell.
I then inserted these LED halo rings
The reason I didnt just fit these is because they just look terrible on their own and the halo case really hides it. So now when they are off there are just white rings on the fog lights, not those nasty cheap looking LEDs.
Also, its a perfect circle now which makes it look a million times better. Here's how it looks now.
First of all you need to fix the DRLs to your car. This will vary depending on where you are putting them and what type of DRL they are, so i cant really advise you too much on how to do this. Mine just stick on with strong 3M double sided tape.
Once you have fitted the DRLs it's time to wire them up.
The best way to do this is to remove the headlights to give you better access (in my case, the backs of the fog lights).
Once the lights are removed, bring the wires from the DRLs over the the near side of the engine bay (side with the battery). In my case I had to buy extra wire to get the offside DRL to reach the other side of the engine bay.
Connect the wires from the DRLs to the black wires coming from the relay.
Now its time to connect the relay.
The blue wire connects to the battery earth. This is where I connected mine:
And then connect the red wire to the positive terminal:
You then have one orange wire left on the relay.
This has to be connected to the positive wire of the headlight (allowing it to turn off when the headlights are on).
The wire comes off the plug that goes into the back of the headlight. The wires are numbered and it is NUMBER 1 that you need to conect the orange wire of the relay to:
To save you cutting into your car electrics I bought a pack of these for 99p:
Put the crimp over the wire and insert the orange wire to the other side from the relay. Squeeze it with some pliers and clip it shut.
Now this is all connected up, try it out.
Turn the engine on, after a few seconds the DRLs should turn on. turn your side lights on....the DRLs should still be on. Turn your dipped beams on.... if done correctly, they should now be off.
If this is all working correctly it's time to clean up...
Get a packet of small cable ties and secure and loose wires and secure the relay down:
Wack the headlights back in and voila!
This relay also includes a 'follow me home' feature which means that they will stay on for 20 seconds after the engine is turned off.
