Haz93
Member Since 27 Feb 2012
Offline Last Active Apr 28 2013 11:10 PM
In Topic: Focus Bulb Lists
22 April 2013 - 06:26 PM
The ST/RS Xenon headlights use
2004-2007 Osram D2S bulbs dipped
2008-2011 Osram D1S bulbs both dipped and main
These work as both dipped and main beam as they are BiXenon, meaning there is a shield in the projector that lowers when the main beam is required
In Topic: Rear View Dim Mirror
25 March 2013 - 07:16 AM
I retrofitted this. You maybe lucky as most cars have the correct loom already. The wires are taped up in the headlining, you need to remove the interior light and the square bit around it, then you should see the loom taped between this opening and the start of the windscreen. If you can't see the taped wires then sorry you don't have the right loom. As for fitting the mirror the mount is different to the manual mirror. You will need a new windscreen/mount or to modify the new mirror to slot onto the original mount
In Topic: Haz93's Zetec S
20 March 2013 - 11:42 AM
Okay the Bi-Xenon's are back on Ebay if anyone is interested :)
http://www.ebay.co.u...=item19d9d556fb
In Topic: First Post So Hello :) - Lots Of Focus Zetec S Questions
20 March 2013 - 11:29 AM
Personally from what I have heard on this board, the 1.8 tdci is a well built reliable engine and that's the on I would choose, especially due to the short distances it will be used for with the dpf issues. But petrols are recommended for short journeys as diesels take around 15 mins to warm up and are unefficient before that point.
The titanium 1.6 petrol I has only the 100bhp option. The Zetec S is the only one to use the 115 bhp engine between 2008-2011
The Zetec S does look the best though, better than the ST in my opinion :) especially in white :D
But that's just me, I wouldn't buy a car any other colour :)
Take a look round at some of the mods on the forum too as some are super simple but make a real difference, like the RS rear lights mod that I did completely changes the rear end :)
In Topic: Xenon Bulbs
20 March 2013 - 11:09 AM
As mentioned eBay is the best place, there are no real shops for oem or aftermarket xenon bulbs
