Haz93
Member Since 27 Feb 2012
Offline Last Active Jul 04 2014 04:36 PM
#254420 Focus Bulb Lists
Posted by Haz93 on 22 April 2013 - 06:26 PM
The ST/RS Xenon headlights use
2004-2007 Osram D2S bulbs dipped
2008-2011 Osram D1S bulbs both dipped and main
These work as both dipped and main beam as they are BiXenon, meaning there is a shield in the projector that lowers when the main beam is required
#225743 Mk 2.5 (Facelift) Led Rear Lights
Posted by Haz93 on 11 January 2013 - 09:06 AM
250 new from ford dealers or 220 on some dealer websites
#224938 The Ultamate Rear Seat Cover
Posted by Haz93 on 07 January 2013 - 01:14 PM
Mine are all leatherette mate. You don't need to take off any of the plastic trim pieces to fit the covers, the headrest ajuster/button things the material just pushes underneath them. I did remove the trim around the height adjuster to see if there was any more room for the material, but there wasn't any need really as like the headrest adjuster, the material just pushes under the trim and doesn't need to go too far under. The hardest part to do is getting the elastic loops for the metal hooks down under the front seats, but if you or someone who can help has small hands its not too hard.
#224935 The Ultamate Rear Seat Cover
Posted by Haz93 on 07 January 2013 - 12:56 PM
Just email them for a quote on your chosen colours/range, think the guy I spoke with is call Lucio. He said the covers are made in Italy but they still had a very reasonable delivery time considering they are made to order. Just mention I recommended you :) if some more people decide to get these covers I could talk to him about an owners club discount.
I had a problem with mine as they had put a lumbar support lever hole on the passenger seat where there was no lever, but they sent out a new upper seat section free of charge with quick delivery. I would defiantly use them again
#224932 The Ultamate Rear Seat Cover
Posted by Haz93 on 07 January 2013 - 12:39 PM
They are relatively easy to fit, but as they are car specific they can be tight. They took me a few hours to fit properly and make sure all the creases were out. The rear backrests just Velcro to the rear of the seat, the seat sections are attached with metal hooks to the underside of the seat frame. The front backrests Velcro at the bottom but can be tricky to get the material between the backrest and the lower seat. All in all I think they were worth the money.
Mine were the Tiffany range, came to 250 with the white inserts and white contrasting stitching. Yes mine are the black and white ones, if you do decide to get some I can always post some pics of how they are fitted :)
#224926 The Ultamate Rear Seat Cover
Posted by Haz93 on 07 January 2013 - 12:23 PM
If you are looking for some quality fitted seat covers I really do recommend jcseatcovers.co.uk I have purchased a set for my focus and they are a perfect fit, easy to clean and look very smart
Just noticed they actually have my pictures on there website :)
#224583 Mk 2.5 (Facelift) Led Rear Lights
Posted by Haz93 on 05 January 2013 - 01:52 PM
That is another example of fords rip off prices. But got to say they do look very smart :)
#224332 Mk 2.5 (Facelift) Led Rear Lights
Posted by Haz93 on 04 January 2013 - 07:37 AM
Ah, I must have missed that then :(
I can't imagine that being more that 15/20 each. But the seller still should have shipped them too.
#224292 Mk 2.5 (Facelift) Led Rear Lights
Posted by Haz93 on 04 January 2013 - 12:21 AM
I'm not sure if they sell just the loom. I have a feeling they won't as the whole light unit and loom are one part on the parts catalogue
Best to chase the seller up or get a refund if they can't provide it.
#224233 Mk 2.5 (Facelift) Led Rear Lights
Posted by Haz93 on 03 January 2013 - 07:14 PM
No they should come with a loom for all the bulbs. The loom is joined together with the LED wires, there is no connector for the LED that is seperate. Maybe the ones you have are modified in some way, any chance of some pictures
#219922 Focus Zetec S Kit Fitted
Posted by Haz93 on 06 December 2012 - 10:56 AM
The 19 inch ones are from the mondeo titanium X, so you will need to check they will fit first. I imagine they are very wide, an the RS has the wider arches to cope with the 19"s
#219088 Mk 2.5 (Facelift) Led Rear Lights
Posted by Haz93 on 30 November 2012 - 11:42 AM
This is a video of the OEM LED lights on an ST
http://www.youtube.com/watch?v=wrCbfU02vm0
There are some pics of them on here, they have a straight pattern and double sided LED side lights
http://pumabuild.com...roducts_id=2151
Although the price they charge is double that of Ford Parts :S
These are my standard, single sidelight bulb halogen lights with a honeycombe pattern
Hope that makes it a bit clearer mate. The LED ones are a hell of a lot brighter too :)
#219073 Mk 2.5 (Facelift) Led Rear Lights
Posted by Haz93 on 30 November 2012 - 10:21 AM
Managed to get mine for 70 for both and 20 quid postage :D
Just got to find the seller that doesn't know what they are selling. They were listed as 'titanium rear lights' but still 140 is still worth it as they are well over 200 new
#218941 Mk 2.5 (Facelift) Led Rear Lights
Posted by Haz93 on 29 November 2012 - 03:20 PM
The LED lights were standard on any cars with xenon headlights, so ST 2, ST 3, RS and any titanium, Zetec S with the X pack ( better lights pack )
#218928 Mk 2.5 (Facelift) Led Rear Lights
Posted by Haz93 on 29 November 2012 - 02:42 PM
Just the standard clear ones with the side lights only in half of the unit. The LED ones have side lights in both sections ( indicator an brake )
The standard ones have a honeycombe shape, the led ones are in straight lines
Bit hard to describe :P
