Member Since 20 Dec 2008
Offline Last Active Sep 07 2013 10:34 AM
Front Side Lamp Won't Fit!
01 September 2013 - 05:04 PM
I know this sounds a silly question, but how is the front side lamp fitted on a 2000 Ford Escort?
I need to replace the nearside side lamp before my MOT next week as I've suddenly discovered the old one was broken. Visibility is very limited but I can see an alloy tube behind the headamp cluster where it goes and there's the plastic sidelamp holder (black) hanging loosely on its cable. The lamp holder is about the same diameter as the alloy tube so it doesn't slide inside. So it must be the bulb itself which slides into the tube. But the bulb I've bought from Halfords ("exterior/interior bulb, 12V 5W, code 501" is written on the blue packet) is slightly too large to slide into the alloy tube. If I pushed it more, it'll just fracture. Anyway I would've thought that relying on an interference fit between glass and metal is inadequate design!
Have I got the wrong bulb? Or is there a rubber tube, say, which acts as a sleeve for lamp and alloy tube (sliding over both) that's missing? If so, I can pop intio a dealer before I go to the MOT and get one. Or bodge one up with insulation tape the night before just for the test.
I just haven't got the time in the next week (I'm working!) to take the headlamp unit out to see what's what.
I've looked on the other side (offside) but visibility there is even more limited! I don't want to remove that bulb in case I can't get it back--I don't want to compound the problem.
Can anybody explain what's happened?
Otherwise I'll just have to do the pathetic thing and ask the MOT tester to put the bulb in for me--if something IS missing, he won't have it and that'll be a fail..........
Replacing Fog Light Lens
09 February 2013 - 12:11 PM
I've just noticed the fog light lens on my Escort Finesse Estate (2000) is smashed, probably by a stone. The Haynes manual gives no indication of how to remove the light unit to replace the lens--I assume the lens IS sold separately. It just tells me how to replace the bulb! Could somebody tell me how to remove the unit please?
And, by the way, are the fog light lenses sold separately?
