swhite87
Member Since 03 Mar 2012
Offline Last Active Yesterday, 03:09 PM
In Topic: Mk1: Fix Or Scrap?
01 March 2013 - 09:15 AM
http://www.ebay.co.u...=item4135e649b0
http://www.ebay.co.u...=item4d088ae2da
http://www.ebay.co.u...=item2324f00f76
http://www.ebay.co.u...=item1c2dd45830
http://www.ebay.co.u...=item2324561bd1
http://www.ebay.co.u...=item2ebfda3aae
their is a list of all the major mechanicals you mentioned,  i personally would try and save it (but try and use a recommended independent garage instead of ford as it will save you a fortune)
it all comes in at just under £220 too which isn't bad at-all i dont think  :rolleyes:
In Topic: Gearbox Problem's :(
02 February 2013 - 12:58 PM
all sorted :D ,   the collar had sheared so it's cable-tie'd into place on the bracket for now until i can get round to changing the cable's for new one's,     thanks for all the help guys,  much appreciated :rolleyes:
02 February 2013 - 09:07 AM
just had a look and the locking tab on the ends are fine but on one the piece where it attaches to the block looks to have come apart with a spring and what looks like a white collar loose causing the cable to move about.....
could this be the cause??????
01 February 2013 - 10:48 PM
no slipping and still plenty of pull in every gear that works the clutch has only done about 15k, just hoping it's something simple
In Topic: Drive Shaft Removal
04 January 2013 - 12:20 AM
they are very tight, easiest way i found was loads of wd-40 a lot of patience
