Member Since 03 Mar 2012
Offline Last Active Mar 12 2013 12:12 AM
In Topic: Yellow Warning Light On Instrument Cluster Of 2006 Fiesta
12 March 2013 - 12:12 AM
Dear Staff, the instrument cluster I have is just like the central one of the 3 that you showed me and the yellow light comes on very close to the figure 7 on the tachometer. After Sam's reply I'm just wondering if it might be a loose connection in one of the door lock's, will look at that possibility as soon as I can but its only happened a few times. Dan
11 March 2013 - 06:00 PM
Hi Staff, there is no symbol next to the light but I noticed that when I open the drivers side car door this yellow light goes on and then goes off when I close the door again.
In Topic: Ho Do I Change The Date And Time On My Mk6.5
30 March 2012 - 04:20 PM
Thanks Ashleigh, your instructions worked first time, just perfectly. HAND, Dan
In Topic: Wiring In Auto Fold Mirrors - Help With Disconnecting
15 March 2012 - 07:55 PM
I had a problem with my mirrors making a loud clicking noise when I turned off the ignition. I removed Fuse 8 @ 7.5 amp fuse from the fusebox, located behind the glovebox and this disconnected power to the mirror motors and solved my problem. I prefer it this way because its an extra that I don't really need.. This has no effect on the heating element which warms the mirrors when the rear window heating element is turned on.
