Hi all,
Took my car for its MOT test today and it failed on front wheel bearning having excessive play. (I take cars to local council garage who do not fix cars,only test them!). I thought it was a bit odd as I only had a new bearing and drive shaft fitted a few months ago. Anyway, got it home and in the garage and jacked it up to have a look. Turns out that the hub nut was loose so I have tightened it up and now the 'excessive play' has been cured. My question is - should the hub nut have a locking device as cars I have worked on before have always had a split pin to hold it tight.
Incidentally,I only tightened it up with a spanner so will get a socket - think it's a 32mm if anyone can confirm?
- → Viewing Profile: Topics: fintious maximus
Support the club!
- Group Members
- Active Posts 108
- Profile Views 378
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Male
Ford Model
Modeo Estate 2.0 Zetec
Ford Year
2001
UK/Ireland Location
Yorkshire
Annual Mileage
5001 to 10,000
Contact Information
- First Name Andy
0
Neutral
User Tools
Latest Visitors
Front Wheel Hub Nut Loose
23 January 2013 - 05:15 PM
Leak - Looks Like Water/power Steering Fluid?
20 January 2013 - 11:16 AM
Hi all,
Can't get under the car to look properly as i'm on crutches at the moment. My 2.0 petrol has a smallish puddle under it (towards front of engine on drivers side) which seems to be a mix of water and redish fluid. I've had to top the power steering reservoir up but not coolant reservoir. Any ideas what this may be? It's in for MOT on Weds and would like to sort before if possible.
Slight Hesitation At 2000 Rpm
21 July 2012 - 07:48 AM
Hi all,
Just looking for some advice please. Car hesitates slightly at 2k rpm. I've changed plugs, leads and coil pack but it's still there - even tried another coil pack though admittedly not a Ford original. Is there anything else that could be causing this niggle? Also changed fuel filter!
What Are Symptoms Of Failing Leads/coil Pack?
07 July 2012 - 12:28 PM
Hi all, replaced plugs,leads and coil pack about 3 months ago as the car was juddering a bit. Bought bits on Ebay and last week the car has started to judder a bit when holding at around 2500rpm. I'm thinking rubbish leads or coil pack but wanted to see what you thought before I buy better ones.
Someone suggested it may be the dreaded swirl flaps on their way - are they similar symptoms?
Thanks in advance
Thanks in advance
2.0 Zetec Coil Pack
05 July 2012 - 05:24 PM
Just bought a Motorcraft coil pack on ebay and notice that the HT lead numbers (1-4) are in a different order to the coil pack already on the car. The part number is the same other than the first four digits but it is advertised asbeing for a 2.0 petrol - should it work okay?
- Privacy Policy
Find content
