GJC
Member Since 08 Mar 2012
Offline Last Active Mar 13 2015 07:26 AM
#464721 Econetic 1.6 Diesel Recall
Posted by GJC on 12 March 2015 - 07:03 PM
Dragging back an old topic...
There is a recall on the parts replaced in in the Recall, if you had your car in under this Earlier  recall they need to check the actual unit they used really was the waterproof version,,,
Apparently most dealers will have the parts in already...
#454717 Dash Cams
Posted by GJC on 15 February 2015 - 01:50 PM
Way I see it is if something happened and I need to show the footage I don't want a el Cheapo special that's hard to make out anything, most cams are fine in the day its night that's the issue.
Mobius are about £50 it may be a false economy to go cheaper....
#441115 Cruise Control Retro Fit Help Required Please
Posted by GJC on 02 January 2015 - 01:46 PM
Nathan used to have a guide to check the wiring on the FiestaWiki pages but it looks like its gone.  I've uploaded it to Drop box.
https://www.dropbox.... Check.pdf?dl=0
I'm not trying to steal Nathans works, just make it accessible..  Look at the PDF, if you have the wiring in place then there's a good chance that you'll have the rest of the wiring and parts inplace.  If the wiring in the steering colum is missing then its possible but will need a lot more.
#437360 Fiesta Mk7 Pre-Facelift Esp Switch
Posted by GJC on 17 December 2014 - 08:02 AM
This link may help -  http://www.fordowner...-12#entry194289
Its from when I took my switch apart to add the ESP disable to my existing parking sensors switch.
They are not discreet switches, but a preassembled circuit board..
#436908 My New Mobius Dashcam
Posted by GJC on 15 December 2014 - 12:52 PM
Been thinking about a dashcam, while cost is not irrelevant, I don't want to buy something cheap that's no use, but then again I don't want something obviously on show.
Coming done to a A118 and a Mobius, anyone have experience of both or can suggest anything else?   I'm not worried about the wiring in as that's needed in either case, my priority is a discreet set up so tis not too obvious.
I plan to put in the submarine lighting LED mods at the same time so I've wires to hide regardless....
#192958 Spare Wheel To Fit Fiesta?
Posted by GJC on 12 July 2012 - 06:33 AM
Try breakeryard.net ( I think it's .net) to search scrappies. My spare cost £25 plus £20 for the Jack. Spare came with tyre and when it arrived the fact the tyre has the little nubbins on it it's never been used.
