ippy
Member Since 11 Mar 2012
Offline Last Active Yesterday, 06:03 PM
How To Change The Regulator On A Mk1 Focus
29 April 2013 - 05:15 PM
:D I DUNNIT FINALLY :D i fitted my new window regulater i done a  guide hope this helps, :)
Attached File  How to change the regulator on a MK1 Focus.pdf   666.75K   18 downloads
Intermitent Wipers!
14 March 2013 - 06:09 PM
when you push the windscreen wiper stalk down is it supposed to do a complete wipe of the screen automaticaly or do you have to hold the stalk down?? :unsure: cos when i push down and let go the wipers stop until i push it again , all other modes are fine, could this be a relay or something? :blink:
Bg244, Or Bg248 With Cetane Boost
13 March 2013 - 06:31 PM
Ive read a lot about BG244 but ive seen 'BG248 WITH CETANE BOOST' is this the same or as good as or better?  has any1 used this before?
Injectors Cleaning?
28 February 2013 - 06:38 PM
<_<  can anyone tell me if it is possible to take the injectors out and clean them yourself? cos i just been told that  1 possibly 2 of my injectors are poorly (rough idle) i was just wondering if you can do it yourself?
Air Breather Pipe Valve Thingy!!!
20 February 2013 - 06:45 PM
on my focus as you look at the engine there is a little pipe on the right i dont know where it comes from but i think its some kind of breather pipe, half way up it joins into what looks like a anti return valve and another smaller pipe comes off the top of this into a rubber elbow and goes off somwhere else, mine has snapped off and im not sure wot it is called so i can get one off internet or is it a ford jobby,
only noticed tonight will try and get a piccy though,
