Member Since 20 Mar 2012
Offline Last Active Apr 04 2012 12:34 PM
In Topic: Fusion 2 Hellp
29 March 2012 - 01:07 PM
thanks Leo, if you do change your pump and it fixes the problem, let me know and i will chase my garage
26 March 2012 - 01:00 PM
i too have a problem with my 2008 ford fusion steering, like yours it is fine when driving but not good when doing manoeuvres, also slight straining noise on full lock. took back to the guys i got it from and they said its because its an assisted manual power steering set up which relies on the engine rather than an electric pump set up which does not, this makes sense as when revs are high steering is easy. I would be interested if changing your fluid helps as this would mean they where spinning me a line and it is a fault
