DSC_0696.jpg 383.05K
74 downloads
- → Viewing Profile: Posts: Sam Price
Support the club!
- Group Members via FB
- Active Posts 5
- Profile Views 195
- Member Title Newbie
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Not Telling
UK/Ireland Location
Please Select
0
Neutral
User Tools
Friends
Sam Price hasn't added any friends yet.
Latest Visitors
In Topic: Ye Old Flashing Glow Plug Light But Can't Find Anything
26 March 2012 - 11:31 PM
here is a photo with the first solder I did- excuse my soldering, it's not great and I'll just have to see how long it lasts!
74 downloads
74 downloads
26 March 2012 - 11:17 PM
For any of you who are interested or are having a similar problem I've fixed the problem so far.
I took apart the turbo actuator housing for the umpteenth time but actually checked each solder joint that comes off of the circuit board to the take power to the motor...a small delicate nudge on each one is enough to see if any are loose. I also checked carefully with a multimeter for continuity- you want to get your multimeter probes on the piece of the joint that is attached to each contact which is quite difficult otherwise you end up just testing the solid wire and always get a positive result...
Anyway, two of the joints were loose and had come adrift very very slightly after only thinking it was one- enough to short and set the flashing glow plug light off and set the turbo with no boost.
So after reading about peoples attempts I took the plunge and got a dremel-type tool with a tiny abrasive ball to get rid of the tin coating on the contact pad where the joint is attached to. This left a nice copper surface for me to carefully solder the joints back on. Just to let you know my soldering iron is a piece of poo that I actually got free, has no temperature gauge or anything and I still managed to secure the joint with a fairly tidy solder.
The actuator was then put back on the car and I gave it a start- no flashing light. So I get the engine nice and warm with a test drive, come back and then restart. Again, no flashing light and engine running as normal!!
Will let you guys know if this fix works with more hot starting etc
SWEEEEET
SWEEEEET
25 March 2012 - 08:44 PM
Does anyone have any other suggestions?
Is it possible to use a different actuator unit on my turbo, where and who have said that you have to get the whole assembly? What would actually be calibrated between the actuator circuit/motor and the turbo?
25 March 2012 - 07:13 AM
It seems to be yes. I'm not really sure how to check the joints with a meter and if I did wouldn't they just read OK because it works fine when I start from cold?
- Privacy Policy
Find content
