civil-zz
Member Since 28 Mar 2012
Offline Last Active Mar 10 2013 07:44 PM
In Topic: Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
24 September 2012 - 04:24 PM
please reference pics below...
Hmm.. Unfortunately I know nothing about *-CD clusters, only -A* and -B*. I'm sure that we have no any parts like this in Russia.
Could you please take a photo of your cluster and share it for me?
Thanks in advance..
mrmetallica,
i's necessary to put all three files in one folder to avoid this error.
nuno8210,
eco mode will be enabled in any case, it's the part of firmware. Shift up indicator will not work until you reprogram your PCM with a special firmware. unfortunately I don't know it's number..
Nitemare,
glad that all now ok with your and your friend's cluster :)
any body done this ?or know where can get the soft ware.
I had done it with my car - all works perfectly, fold and unfold.
unfortunately I think you can't get it anywhere else, only with DarkLeo's adapter and firmware. as I know it's a very hard work to rewrite a firmware - this work took a several months for him
james_60,
Pree,
ADS uses it's own adapter, which has nothing to do with ELM327. It had the proprietary designed PCB and controller firmware.
19 September 2012 - 09:22 AM
any one occur "dashboard not supported" when update ROM ?
my car is 11" focus TDCi
Could you please provide information about your dashboard hardware part number (HEC - Information - Hardware part number), better if it is a screenshot of ELMConfig window. Also I would be very grateful for the photo of your dashboard.
Thank you very much in advance.
29 August 2012 - 09:27 AM
Would it be possible to have the Power Folder mirrors auto-fold when locking the car and un-fold when un-locking the car - similar function to that on the new mk3?
Yes, it possible but not with ELMConfig. It's necessary to total reprogram door module. You can contact with DarkLeo on ffclub.ru, he is the author of a new firmware for DCU with auto-fold option.
02 July 2012 - 07:25 PM
Teabags, I think, no. You calibrate zero condition - headlamp state which autocorrector will keep..
30 June 2012 - 11:33 AM
Hiya Sergey how are you? , have you made any new updates recently?
Hi Preee,
there was some small update (ELMConfig 0.1.1.8), it's availible through the previous link (http://civil.iffc.ru...g/ELMConfig.zip).
Changes:
- working with HCM module, including headlamp autocorrector calibration
- fix bug which appeared if the echo was already switched off in ELM327 settings
- the full bus loging during the work is now availible
- DllPack has gone in past, now universal RuntimePack with installer is used (all Windows versions) (http://civil.iffc.ru...RuntimePack.exe)
