civil-zz
Member Since 28 Mar 2012
Offline Last Active Apr 17 2015 04:25 PM
#469968 Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
Posted by civil-zz on 26 March 2015 - 11:24 AM
emerald293, your issue isn't linked with PATS initialization or smth similar. just issue with elm327 adapter or computer performance. on these modules type (SID206, correct?) PATS init procedure MAY be required only when to update to some calibration levels. if process gets stuck on memory erasing stage then it means that adapter just can't get an answer on erasing command, there is no about PATS. best way is to change your ELM327 adapter. also changing connection speed or USB driver delay could help.
one more point - if you was able to upload your original file then it means that modified file also can be uploaded. second point is whether it can be started after but it can be flashed into the module. seems that you equipment just works unstable.
#439843 Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
Posted by civil-zz on 27 December 2014 - 11:37 PM
i don't know whether a value from test mode used for the pointer behaviour but yes, after TEMP/FULL version flashing the pointer value should correspond to test mode
#439836 Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
Posted by civil-zz on 27 December 2014 - 10:31 PM
Maybe this is a daft question but would anything modified through the ELM software cause the cluster to make a small beep, possibly when hitting a certain speed?
:unsure:
it's a setting in HEC configuration, page 1 (Overspeed warning (120 km/h))
Done, mate! Many thanks for your so precious help... ;)
I've got it, many thanks. bad news - seems that VID decoded completely incorrectly.. and i have no idea what to do with it :unsure:
what is your real VIN, because i think that WF0GWF0GWF0GWF0GW is not a correct one? i'try to get data from as-built service if it possible.
i think you don't mind if i answer your questions here?  :)
FULL and TEMP firmwares are the custom versions modified by our programmer with nickname quickie. TEMP version makes cluster to show the real engine temperature (as you know during warming up by default it shows 90 degrees when real temperature is only 45. and then shows 120 when it a already real danger to engine happens). so TEMP version arranges temperature and it's indication. as I know quickie made this modification for 1.4/1.6/1.8/2.0 engine maps so i'm not sure whether it will work with 2.5. FULL - its a TEMP version with adding a cut off the snow flake indication also. so you're right - its the only differences between them.
your faults with cluster update maybe linked with low speed/big timeout (did you increase baudrate to 500000 bps/decrease usb timeout to 1 ms?) or low adapter quality - its the most often met cause.
the most robust adapter i ever met is the ELS27 which is developed and produced here in Russia. it a bit more expensive then chinese ELM327 (at the current moment as i know its approx $30) but it is built from known components by a very experienced people with multiple functionality checks, it can work with baudrates up to 2Mb/s which allows for example to read SIM28/29 less then 1 minute, and also supports two buses from the box without any switches  :)
P.S. your car looks really cool and amasing, I love it  :)
#439215 Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
Posted by civil-zz on 23 December 2014 - 05:33 PM
2) I think I have a problem with the PCM table because when ELMConfig reads it, I have this:
but my car is a Mk2 Focus RS! Can I change it to the right infos without affecting anything as my car is remapped? If positive, what are the right infos to put in?
Thanks a lot,
Fab
No, it's better not to change anything. seems that RS VID-block coded differently then others.
Could you please press "Save to file" button (leaving your VIN in place) and send saved file to civil-new@mail.ru ?
Great thanks!
#175290 Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
Posted by civil-zz on 31 March 2012 - 08:54 AM
Some good news.. I complete translation ELMConfig, actual version 0.1.1.7, it's available here: http://civil.iffc.ru...g/ELMConfig.zip
Also i added some new features - work with PAM, RCM, Door units, writing VIN in AHCM and HCM, fix some bugs.. And of course, english language now available. :D
