Member Since 04 Apr 2012
Offline Last Active Aug 28 2012 07:10 PM
Mondeo Mk4 Central Door Lock (Its Beat Me)
26 August 2012 - 08:12 PM
Please help me.... My Mk4 mondeo 57 plate has finally let me down (not in a big way). I locked it up the other day and noticed the rear passengers door did not lock. You a can hear the motor trying to pull the lock on though. I have taken the door panel off and all is ok. The cable moves just fine. The door will lock manually.......It just seems the motor has lost power. Any ideas on this? Is this a common fault....
Your help is most wanted
Mondeo Mk4 Still Humming (After Hub Change)
05 July 2012 - 02:39 PM
I have just finished changing my Rear hubs on my MK4 Mondeo (57 Plate) TDCI. I was very please with how the job went, also with memebes input of how to do the job. But the humming continues. I know its hard to describe without actually lisening to the noise, but its sounds like a humming, whirling sound just like something is traveling up the boby. This is in the boot area, you can hear it more on rougher roads, but is still there on smoother, around around 50mph..... Anywhere else I could check where noise or vibrations would travel up the car. Ive even got in the boot and had someone drive me around ( i'll try anything to solve this with spening loads at the dealers) This noise come on all of a sudden. The tyres are both just below half worn (Goodyear, Eagle) This car is as quiet as a mouse normally.....
I hope someone may be able to shine anymore info on it.................
Mk4 Mondeo Rear Hub Change Help Please
02 July 2012 - 09:34 PM
This site has helped me loads... I need help once again. I have recently purchased two new rear hubs for my mk4 mondeo tdci (57 plate) I am going to change them this weekend, but, theres always a but, I have looked at the new hubs, Does anyone know how to remove the torx head bolts without rounding them off. The part of the hub seems to be in the way (part that wheel bolts to ), so you cant get a torx head to make a good fit on the head, or a socket between the torx head and part with the wheel studs attached to.... Excuse my none mechanical description. I want to get it right to save my car being off the road. I hbope someone can help?
My Lovely Mondeo Is Humming(57 Plate Tdci)
12 May 2012 - 03:35 PM
Gents, please help. I was driving back from town today and my lovely quite running Mondeo started to hum from the rear... Its sounds like bearings to me. The car has done 60.000 miles. It is so quite as a rule. I have checked for play in the rear wheels and any grinding noises. All OK, could it still be bearings if none of these signs are evident? If I have to change them do you buy them as a complete hub assembly or just the bearings... I have had no trouble from this car in the two years i have had it. I did change the rear pads about 2 weeks ago and I did have to hit the rear calipers to try and free them a little. But like I said it has run perfect....
I hope someone can help???
Fiesta 1.4Tdci (2010) Humming Noise When Cold...help!!
04 April 2012 - 05:56 PM
Please can anyone help me.... I have just recently purchased a 2010 Fiesta 1.4tdci. All is fine but....... When you start the car after you have left it, it developes a rather strange humming noise from behind the dash (well it seems like that area) This is amplified when it is rellay cold outside. I have taken this back to Ford and they inform me this is a charactaristic of the car. The noise is just like those anoying vuvuzela of the African World cup. I am totally stuck. It is going back to ford in a weeks time. They had it for a week the last time.. Anyone please help if you have heard of this so I can inform Ford just to help them......
