malcolm159
Member Since 23 Apr 2012
Offline Last Active Apr 27 2013 04:56 PM
In Topic: How To Get Power Wire From Battery Through Bulkhead
06 December 2012 - 10:14 AM
If you push a wire coat hanger (carefully) through the rubber grommet where the loom runs through the bulkhead and get a mate to wriggle it about while you look for it behind the glove compartment, (you may need a torch) you can tape the wire to the coat hanger then pull it through. its tricky and you may need a few tries and you may have to get right into the footwell to see
Hi thanks for info, had a look at that before including taking the glovebox out so have a big space to look in but I can't seem to see the end where the wiring comes into bulkhead the passenger airbag is in the way.Have you manged to do this on a fiesta with an passenger airbag fitted.
Thanks in advance
Regards Malcolm
