Once the weather has improved i'll take it out and have a peek at the wires
- → Viewing Profile: Posts: Lawis
Support the club!
- Group Members
- Active Posts 16
- Profile Views 184
- Member Title Member
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Male
Ford Model
Focus
Ford Year
2006
UK/Ireland Location
Berkshire
Annual Mileage
5001 to 10,000
Contact Information
- First Name Lewis
User Tools
Friends
Lawis hasn't added any friends yet.
Latest Visitors
In Topic: I've Got A Confused Clock!
23 February 2013 - 08:28 PM
In Topic: Ford Tdci 1.8 Smoking & P0299 Turbo Underboost
23 February 2013 - 07:51 PM
Turns out it was a split pipe, the first garage must've just not looked well enough!
Thanks everyone
25 November 2012 - 05:54 PM
maf sensor will be easiest to change but you could see if it needs a clean and try this first.
wastegate could be more expensive due to its location
That;s basically what the mechanic said.... really hope it's not the wastegate, as i'm every so slightly broke atm
I had similar problem. The issue is related to a popped hose. Either from the intercooler exit to the intake manifold OR the turbo exit back to the intercooler. Check for oil leakage or spray of oil.
I am pretty sure its a blown hose. Best you replace all your hoses to silicone type ie Samco etc. They last way longer.
Note - my ford hoses appeared to be cracked when i took them out to inspect. My leakage was at the intercooler to intake manifold ( split at the intercooler side)
I was hoping it was this, but they had a look at the pipes when it was in the garage, and couldn't see anything....
21 November 2012 - 11:29 PM
Changed the air filter, and sort of solved the problem, but not 100%
Took it to a garage and they ran a proper diagnostics on it
Reporting the faults to be:
MAF Sensor
Wastegate
He said there is no way to find out which one is causing the problem,
Anyone experienced this?
07 September 2012 - 05:51 PM
Took the air filter out, and it was very very dirty, so getting a new one tomorrow, and we shall see if it solves it.
- Privacy Policy
Find content
