Member Since 30 Apr 2012
Offline Last Active Yesterday, 05:10 PM
#511210 Wheel Alignment
Posted by ppeter7 on 11 August 2015 - 10:45 AM
#510363 Wheel Alignment
Posted by ppeter7 on 08 August 2015 - 06:03 PM
On the mk3 mondeo hatch they have 2 sets of arms that go from the rear sub frame to the hub.The Rearest of them is connected via  bolt with fixed oval washer,which sits in a hole where the sub frame has 2 slots sticking out. So when you slacken off the rear nut in centre of the sub frame you then turn the bolt with oval washer.This will then either push the back of the rear wheel out or pull it in depnding on which way the tracking has to be moved.
#510352 55 Reg Mondeo 1.8
Posted by ppeter7 on 08 August 2015 - 05:44 PM
Thanks in the end i decided on a 54 ghia x 2ltr with 91,000 on clock
#351407 Clutch Bleeding Problem
Posted by ppeter7 on 06 April 2014 - 04:33 PM
looking at it its shows red to clutch
#349201 How To Lock The Doors From Inside?
Posted by ppeter7 on 31 March 2014 - 08:54 AM
is this while your driving as the mondeo have a auto lock if you drive over 5 - 10 mph they auto lock
Motion Auto-lock –MONDEO MK3
Turn on the ignition so the dashboard lights are illuminated. DO NOT start the engine.
Lock the door using the button on the door handle
Then unlock the door (but do not open it) three times.
Turn OFF the ignition.
Turn on the ignition but don’t start the engine - you will hear a distinctive beep.
Lock the door again as before then unlock it (only once this time) - a final beep will be heard.
doors will now auto lock when you pull away. This will also auto lock
the doors in reverse. If you need to disable this feature, then repeat
the steps above.
#332596 St220 Hub Problem - Are All Mondeo Hubs The Same?
Posted by ppeter7 on 14 February 2014 - 10:50 PM
have you tried mondeo spares they have a online catualog there cheap aswell 2nd hand but worth a punt.ive used them a cple times for suspension stuff
#331249 Mondeo Lock Change
Posted by ppeter7 on 10 February 2014 - 10:28 PM
yea its bit more than that because of the immobilizer or pats system control unit under the drivers side of dash lower section by pedals a auto locksmith can program and cut a remote key for £85 thats not a clone key either,hope this helps
#258034 Re Fitting Leather Interior In Mk3 Mondeo
Posted by ppeter7 on 06 May 2013 - 10:02 AM
you would have to change the rear window regulators from manual to electric,which might mean replace door loom to.just check under seats for connection sockets as there colour coded.discounnect battery as ur be messing around with airbag moduals which might put on airbag light
#256389 Mondeo Mot Failure Help Please
Posted by ppeter7 on 29 April 2013 - 05:48 PM
mine failed on high hc's but funny when i brought the car i noticed that the air intake pipe was off cause not realizing why it was off till i put it on and it failed. took it off it passed.
#254363 Starting Problems Key Or Barrel Ford Mondeo 2001 Tddi
Posted by ppeter7 on 22 April 2013 - 03:52 PM
if you have a book pack you might have a sticker in there if not then its off to ford they might have it on there system but more than likely its going to be strip barrel out.unless u got a spare.i paid £5 for mine from ford cut to key no after removeing door lock and barrel
#182891 Has Anyone Tried Terraclean ?
Posted by ppeter7 on 16 May 2012 - 05:25 PM
i did see that to seems gd but obvious its going to take a while 4 it to expand further
