Member Since 02 Jan 2009
Offline Last Active Jan 13 2011 07:28 PM
In Topic: 1.4 Tdci / Mk6 - Chipping A Good Idea?
10 June 2010 - 11:35 PM
Hi mate,
Fitting a Tuning Box will give you the torque you need for more "drive" so you do not need to work the engine as hard and you will be able to use a higher gear because of this..
Why would you not want a remap? It is far better than a tuning box unless it is down to cost..
In Topic: Ecu Re Mapping/chipping
29 May 2010 - 12:24 AM
Hi Bazza,
Remapping is the best way of getting more out of your engine than a tuning box. A remap alters all your ecu settings via new software written for your car.
A Tuning Box the fuelling so is more limited to the changes it can make.
With a reputable Remapping company you will also get a good warranty, our's is "lifetime", whereas with a tuningbox you will not get more than around 3 years.
A remap on your Galaxy will give 30bhp/80nm torque which will transform the way it drives. You will find it easier for towing etc, and it will need less gearchanging so top gear will be used more as less effort is needed due to the increase in torque..:) And you should see a gain in fuelsaving..:)
In Topic: C- Max MPG
01 October 2009 - 05:42 PM
Hi as posted above, disconnecting your battery makes the ECU relearn it's values so you should normally see a difference, also worth doing if you change to shell v power etc..:)
In Topic: sapphire exhaust fitment
22 September 2009 - 06:52 PM
No prob mate, any decent exhaust centre will make it fit..:)
In Topic: HELP xr2 carb problem
21 September 2009 - 11:00 PM
Hi mate, been a long time since i did any work on older engines..:) if engine is running on for a few sec's after being turned off, then it's likely to be pre-ignition, usually down to carbon build up in cylinder head, needs taking off and de-coking as we used to call it..
Just a build up of carbon soot in head and intakes...
