Member Since 01 May 2012
Offline Last Active May 20 2012 07:40 PM
In Topic: Fiesta Mk7 Wind Deflectors
20 May 2012 - 07:35 PM
Posted ImagePosted Image
This is the box that the Ford wind deflectors come in and there made by ????? Answers on a postcard.
07 May 2012 - 10:15 PM
No clips or glue on the Clima ones from Ford, once there fitted they are solid, just need to work the window up and down 5 times as per instructions to bed them in,take the window up first time slowly as you may need to readjust slightly as i did,once they have been in for a few days with the windows shut they should settle in nicely.
07 May 2012 - 08:43 PM
Just picked up a set of front wind deflectors from ford main dealer,Clima profi tinted,finnis code,1555768,fitted in 15mins.£34+vat. Makes a big difference to the look of the car, am well chuffed, now whats next.
In Topic: The 0-60 Time For My 2005 1.4Tdci Is About 40 Seconds....problem?
02 May 2012 - 10:19 PM
Hi Stephen,when the garage were looking at the car did they do a compression test on each cylinder, as you mentioned in the first post you only got half a litre of oil out of the sump,thats not enough oil to lube all the moving parts,theres probably a good chance your piston rings are now worn depending how long it's been used without oil.With half a litre of oil your lucky it still goes at all.
