Member Since 04 May 2012
Offline Last Active Sep 01 2012 01:20 PM
Central Looking Problem
23 August 2012 - 09:47 AM
One issue fixed now want to try and get another fixed
All doors lock with the Key fob
All doors lock with the turn of the key
All doors unlock with the key fob
All doors unlock with the turn of the Key
Now this doesn't happening all the time and when it does it may only happen once or could happen 5 or 6 times
Open the car with the key fob as normal get in start as normal start to drive off and i will hear a noise as if the car is trying to unlock. Like i have a sticky latch
Will maybe make this noise once or like this morning 5 times
Ive Lubed up the latches with Graphic Lube changed the batteries in both key fobs
Any ideas anyone Wire issue maybe?? Lock latch on its way out ???
Thanks for your help :)
P1632 Smart Alternator Faults Sensor/circuit Malfunction &
22 August 2012 - 09:30 AM
Keep getting this error "P1632 Smart Alternator Faults Sensor/Circuit Malfunction"
Had a new Alternator fitted new battery and now this
Has anyone had it before
I think it could have something to do with the Smart Charge Wiring ??
Battery Light, Abs Light Radio Turns Off And Car Wont Start
04 May 2012 - 10:03 AM
Good morning
I brought a 56 plate Ford Focus Titanium with 40k on the clock. Real nice car to drive had it a week and something strange started to happen
Now after dropping the other half off at work the battery light came on and shortly after the ABS light came on. Now this model has the Auto Lights and they came on to. But if I turned off the lights the ABS light went off.
Now that all well and good but it was dark so the lights had to stay on. The car rolled to a stop and would start so I left it for 10 mins and managed to get it starting again. But about 5 mins later it all happened again but the Radio turned it self off and on this time
Now got it home and a mate brought around a jump pack. The car wouldn't start again so we hooked the jump pack and it started straight away.
Phoned the dealer and he said he put in a new battery before I picked it up.
Any idea's what this could be
Edit - My other half did say she heard a strange ticking/whining noise when standing still
