If you remove the plastic panel that the gaiter goes through, (the bottom one) its easy.
The gaitor clips off the bottom of this panel.
But yes, turning it anticlockwise will remove the gearknob. But since the gaitor is attched to the knob you need to take it off to. To remove the plastic panel just pull up, theres 4 metal clips holding it and 2 plastic ones, you need to pull quite hard. Then just clip the gaitor and unscrew the gearknob! ![]()
Find content
Male
